Results 1 to 14 of 14
    Jul 2018
    Ma.
    1984 Mercury 115 EL inline 6
    1984 mercury 115 EL inline 6. I was out running WOT for about five minutes then Boat started coughing and dropped to 3500 RPM. I checked compression 125 to 130 in all six cylinders. Checked spark , have spark on all six( used inline spark tester with light bulb). Changed fuel water separator, it had a little water in it not much.
    Checked timing was 3 degrees at idle and 19 degrees at wot, specs say 6 degrees at idle and 21 degrees at wot. With today's fuels I am happy with that. Will go to 5500 in neutral. Can only get 3500 rpm under load. Checked the screen in fuel pump and it looked brand new.
    May 2006
    Sugar Grove IL./Eagle River WI.
    Probably stator. You need a dva meter to be sure or another known good stator. High speed windings bad.
    Jul 2018
    Ma.
    SS170 I think your on to something.i don’t have a dva meter but I will be checking continuity and resistance when I get home from work today. Quick question could it be the rectifier messing things up? I noticed on my volt gauge that my batteries were at 13.9 usually there at 13.1 tops.
    May 2006
    There's 3 sets of windings in the ADI stators, low speed (up to about 3500rpms) high speed (3500 on up) and charging. 13.1 or 13.9 I believe are both OK. A bad rectifier would jazz up your tach and or not charge at all. CDI has a trouble shooting guide on their website. It give the resistance values and the DVA values. If your lucky, you may be able to diagnose this just with an ohm meter (open windings, high or low resistance). Otherwise a DVA is what you need. The last inline I worked on had open high speed windings, no DVA needed. New stator and fixed.
    Jul 2018
    Ma.
    Thanks again SS 170 I will check tonight. I really appreciate the help.
    Cleveland/Marblehead OH
    Take a quick look at the fuel pump check valves
    Sold the Skater, missing it everyday
    Jul 2018
    Ma.
    I will do that as well. I am not changing anything until I know it has failed.
    Jul 2018
    Ma.
    I tested the stator and it is bad. What else should I replace? Bare minimum for now?
    May 2006
    That’s all I would change....... unless you have very deep pockets������
    Jul 2018
    Ma.
    Nope. I do not.
    Jul 2018
    Ma.
    I was just worried that the stater is now working at 100 percent maybe the trigger will go or the rectifier or the boxes.?
  12. #12
    May 2006
    .On my 115, I just changed the stator and it’s been fine ever since. And, as you know, you need a mercury flywheel puller.
  13. #13
    Jul 2018
    Ma.
    Ok. Stator only. (That’s the answer I wanted anyway). Yes I know I need the Mercury flywheel puller.
    Thanks SS170.
  14. #14
    Jul 2018
    Ma.
    So I ended up changing my stator, trigger and rectifier. The wires were toast. My question is do I need to do a full lync and sync or can I just do the timing? Either way any links to how to do that?
  1. Need a repair manual for 1984 inline 6
    By Bluecollerboater in forum Outboard Engines
    Last Post: 04-03-2019, 09:01 AM
  2. 1984 and later inline 6 tower of power
    By demoore17 in forum Technical Discussion
    Last Post: 06-08-2017, 02:41 PM
  3. 1980's inline 75/85 vs. 1984 70hp Meric
    By cm21 in forum Technical Discussion
    Last Post: 05-10-2008, 12:11 PM
  4. 1984 115hp inline - data
    By Clams Canino in forum Technical Discussion
    Last Post: 07-30-2002, 03:09 PM
