Results 1 to 5 of 5
07-16-2019, 02:24 PM #1
23 Eliminator Daytona - props spinning same direction?
Because of the diminishing availability of counter rotating drives and parts the cheap answer would be to run 2 standard rotation lowers. In this case, they are 2000 Johnson 225s. Any ideas how negative the effects will be? Slight or forget about it? Thanks in advance for your input. PaulO
07-16-2019, 05:13 PM #2
Steering at higher speeds would be awful say 60 ish and dangerous
07-16-2019, 05:49 PM #3Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,641
- 606
- 921
- 1698
- 7138
- 3 Post(s)
Hard left turns are sure to add some excitement to your day. What you could potentially spend repairing your boat, self, and passengers is a lot more then the cost of setting it up correctly-find a counter rotater.
07-19-2019, 11:04 AM #4
Another negative other than stated above of running two standard rotation is that at high speed you will start to "crab walk" the boat to the starboard....that makes straight runs a little scary
nitro_rat liked this post
07-20-2019, 06:01 PM #5
I thought it was a bad idea. Thanks for confirming. Definitely will not do this. PaulO
Looking for a eliminator Daytona 22-25
By Sangersully in forum Hulls WantedReplies: 0Last Post: 04-10-2019, 12:41 PM -
WTB - Eliminator Daytona 22
By ONE-A-DAY in forum Hulls WantedReplies: 4Last Post: 09-27-2016, 04:46 PM -
By blowitup in forum Hulls WantedReplies: 12Last Post: 07-12-2016, 08:43 PM -
21' Eliminator daytona
By togi in forum General Boating DiscussionReplies: 12Last Post: 07-14-2003, 07:34 PM -
Eliminator 19' Daytona set up
By Allison's Allison in forum Technical DiscussionReplies: 15Last Post: 09-05-2002, 09:35 AM
