Results 1 to 9 of 9
    May 2018
    NH
    14' Thundercat Inflatable Catamaran, 80HP Yamaha -- NH $7,500
ID:	444551Click image for larger version.
ID:	444552Click image for larger version.
ID:	444554Click image for larger version.
    $7,500
    2014 Gemini Zap Cat Evo 1
    Yamaha 70CES short shaft, tiller outboard
    Aluminum trailer
    Cover
    this boat went 59mph with a 50hp tohatsu on it
    i expect about 70mph with this ~80+HP yamaha, but i have lost interest in pursuing because i bought a bigger boat.
    Details:
    Hull is in excellent condition, a 9/10, holds air excellent and has NO leaks of any kind
    Trailer is in great shape too- has wide tires for sandy launches, frenched in lights, etc.
    Cover is good- keeps the boat out of the weather
    Props: I have 3, 2x18p, 1x21p which has a bent blade
    Motor needs tinkering...
    it runs excellent but is loud - because the mid section is open. This could/should be patched
    Main jets seemed a little bit fat when i drove it (only drove it once)
    The lower unit is freshly rebuilt (professionally) with new water pump, seals, shaft, etc.
    90HP carbs
    welded crank for reliability
    ported cases
    new reeds
    pull start only
    premix only
    no tilt/trim
    steering damper
    Although it's 'turn key' and can be driven immediately, it's loud.
    Fix the noise issue and you'll be golden.
    if you add up the pieces of this package, it is valued quite a bit higher.
    If you want a better price, i can start selling off the pieces seperately
    text me (NH Area code) 320-6333
    May 2018
    NH
    BUMP
    TTT
    moving and it must go!
    Mar 2009
    Saint Lucie Florida
    Just curious, would you sell engine seperate and if so how much.
    May 2018
    NH
    Quote Originally Posted by TwzteD View Post
    Yup!
    make an offer via PM or text
    May 2018
    NH
    $6,000 for all
    TTT
    May 2018
    NH
    TTT
    Someone just make an offer on this stuff.
    Moving and must sell some or all!
    Let me know your absolute bottom number and I will make a fast decision-
  8. Likes TwzteD liked this post
  9. #8
    Jan 2010
    Pacific NorthWest
    Interested in hull only! PM me if available, thx
  10. #9
    May 2018
    NH
    Quote Originally Posted by fastbyferreira View Post
    Sold
  1. Replies: 0
    Last Post: 02-07-2019, 08:16 PM
  2. Prop for SLT Thundercat Inflatable
    By Bartl1ra in forum Props, Setup, and Rigging
    Last Post: 04-10-2018, 07:19 AM
  3. Thundercat inflatable repairs
    By riverrat321 in forum Technical Discussion
    Last Post: 03-29-2005, 11:18 AM
  4. Thundercat inflatable repairs
    By riverrat321 in forum General Boating Discussion
    Last Post: 03-22-2005, 04:57 AM
  5. Thundercat inflatable advice needed.
    Last Post: 03-04-2005, 08:39 PM
