Results 1 to 7 of 7
    Sep 2007
    bay city mi.
    Optimax air rail dump hose
    Anybody just dump the air under the skirt? Putting on a x mid, but wondering if it's really necessary to drill and tap it to dump with the hot water.
    Dec 2013
    georgia
    I haven't done it but that famous optimax air pump noise is magnified by five if u let it dump like that. Early optimax motor had it ran back into intake plenum
  3. Likes XstreamVking, kct11 liked this post
    Jun 2017
    Connecticut
    Yea I messed up when i did mine, I just drilled a hole in the floor of the lower cowl and have it exit there. You can here the puffing of the air but the engine is so loud to begin with I don't think it affects much.
    https://www.screamandfly.com/showthr...995-175-carbed
  5. Thanks kct11 thanked for this post
    Sep 2007
    bay city mi.
    That the info I was looking for, thanks! Going to drill and tap.
    Jun 2017
    Connecticut
    did this image help you? You talking about a 2.5L right? Small mistake two red circles on the lower pictured silver plate should be on the upper two holes but doesn't really matter as it all dumps into the same area.
  8. Thanks kct11 thanked for this post
    I dump mine into the cowl but have a muffler on the end of the hose to minimize the huffer noise. I plugged the top outlet, drilled and tapped the angled side of it so that it has clearance. Works well and noise is way less intrusive then it was when it went up into the air plenum.
Name:	opti muffler.jpeg
  10. Thanks kct11 thanked for this post
    Likes Fishinmymission liked this post
  11. #7
    Sep 2007
    bay city mi.
    Now that I am home and looking not sure where to dump it. Is it supposed to go in with the exit water, or catch a cavity that is exhaust?
  1. fuel hose from rail to injector
    By bill mason in forum Technical Discussion
    Last Post: 05-26-2018, 02:19 PM
  2. Where to buy billet rigging hose flange for larger optimax hose
    By aggiestckl in forum General Boating Discussion
    Last Post: 05-03-2016, 11:15 PM
  3. promax 225 poppet valve and dump hose ??
    By laglass69 in forum Technical Discussion
    Last Post: 07-06-2009, 05:19 PM
