Results 1 to 10 of 10
    Mar 2012
    Lake Hopatcong, NJ
    2.5 crank big vs small bearing
    How hard is it to fit a 2.5 non-oiler 1.5 top journal crank into a later model 280 block? Do you just use the smaller 1.5 bearing and the matching top cap in the newer block? Or is it much better to stick with a big bearing crank?
    Feb 2007
    lily lake WI
    the question is why put a small bearing crank in a 280 block you can use a small bearing crank in a big bearing motor just got to put a collar on it but I would not be comfortable with a small bearing crank
    Mar 2012
    Lake Hopatcong, NJ
    Because I have one already and it looks like a new big bearing crank is around $2000 :-(
    Dec 2001
    Just use it...bearings fowwle the crank.....JMO...Just don't use plastic....Sand the rings for more.... did I say that????? heeHee..
    Mercury made an adapter to install small crank to big 280 block I have the part number at home dunno if they still make it !!!Ive used it lots of times ...
    Jay
    Jay @ JSRE
    charlotte,nc
    http://www.marineengine.com/newparts...1159-832012T+2
    pretty pricey, it only adapts crankshaft with 1.5" upper journal to big bearing block
    death is certain; life is not
    shreveport,la
    You can find good used big bearing cranks for around 800
    Erik Kiser
  8. Likes Michael J Giesler liked this post
  9. #8
    Mar 2012
    Lake Hopatcong, NJ
    Quote Originally Posted by patchesII View Post
    Thanks. Been looking but so far no luck. Seems like a rare item.
  10. #9
    Feb 2007
    lily lake WI
    Quote Originally Posted by tripower View Post
    I have sold about 10 in the last year if I get more I will let you know $650-$800 +shipping
  11. #10
    Mar 2012
    Lake Hopatcong, NJ
    Great, thanks!
  1. 260 small bearing crank
    By wetsetmarine in forum Parts Wanted
    Last Post: 02-07-2017, 12:34 PM
  2. Small bearing 260 crank
    By 85nova in forum Parts Wanted
    Last Post: 01-15-2014, 05:39 PM
