Results 1 to 4 of 4
    Mar 2012
    Lake Hopatcong, NJ
    2.5L offshore refresh parts list
    When you guys refresh a 2.5L 260, what parts are part of the normal refresh? I know it should get new rings, but should I also be looking for new bearings, etc. every 100 hours?
    I replace most all bearings all gaskets and oil seals l( Pro Marine) , injectors cleaned and calibrated ( Brucato) TDR reed valves (Tony Dukas) all fuel hoses ( injector grade ) and correct Tygon on vent lines ...
    Jay @ JSRE
    Mar 2012
    Lake Hopatcong, NJ
    Thanks Jay. I wasn’t sure if all the crank, upper and lower rod bearing were part of the typical ring refresh. Looks like they’ll cost more than the rings :-)
    Dec 2001
    no need to change out the bearings.... with infiror stuff...If they are good.... cepp em.....The rings are a nudda Issue.... as are the non.... ome head gaskets....JMO...save ya $$$ and when it goes....BANG... then send it to J...No need to have a hfse.... boat meck fix what is not broke......JMO...
  1. Mercury Tech: Parts List
    By 2 De River in forum Technical Discussion
    Last Post: 03-28-2009, 07:32 PM
