Results 16 to 18 of 18
Thread: Need optimax help.
07-15-2019, 04:11 PM #166000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Humm 1b715289 shows 2720 standard opti. Port 889639A02 and star889640A02
from my source for the merc parts.
Steel reeds though you you might have a ph swap or reed swap. You might have to dig in the block and find out if it’s a pro or not pull the numbers off the computer and such
07-15-2019, 08:16 PM #175000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
Just seeing this and reply to your ad in marketplace. I think you would be better off keeping pistons and just finding you some pro xs heads or see if Chaz can maybe rework cylinder head chambers some to work.
Post pictures of cylinder head. Pro xs cylinder chamber is like a half moon lookingLast edited by 2jz; 07-15-2019 at 08:24 PM.
07-15-2019, 08:32 PM #186000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
The different pistons may have to do with the different spray patterns from the air injectors used. Blue/black are for standard optis with the wide pattern and grey is for the proxs with the narrow pattern
1999 200 optimax or 2004 250 xs optimax?
By vmax80096 in forum Technical DiscussionReplies: 7Last Post: 07-26-2018, 12:34 PM -
Mercury Tech: Optimax to non Optimax lower
By btown101 in forum Technical DiscussionReplies: 5Last Post: 07-11-2018, 01:41 PM -
Will 225 Optimax ECU on my 200 Optimax give it more HP?
By paragod in forum Technical DiscussionReplies: 3Last Post: 11-27-2017, 05:18 AM -
Optimax 350
By helios2001ve in forum General Boating DiscussionReplies: 9Last Post: 08-28-2008, 01:24 PM
