Results 1 to 15 of 18
    Jul 2007
    Which optimax pistons 2009 225 pro??
    I ordered 6 pistons from Promarine. They said they fit my 09 225 pro. My mechanic put it together and said the pistons donít clear the heads. I ordered 6-7500 series bored .015 over. Anything that yíall experts can advise me? Seriel number is 1B7115289.
    Dec 2001
    The early pistons were flat..... the newer were domed........just a year ....### changing prob.....Call Chazzzzz.
    May 2014
    Livingston, Louisiana
    I’m pretty sure there is different fuel pockets and some are raised more than others, some oval and some round. Looks like pro marine only offers wiseco for the 09, the 3212 series. Check them out and see if those look like what you need
    Jul 2007
    So can i put heads on from a newer motor? What years would have a bigger chamber?
    Dec 2001
    I think I have the newer heads.......
    May 2014
    Not 100% sure if there is any issues with swapping heads. I broke out the the book and looks kinda like you got the right pistons. Have ya been able to compare whatís the difference by comparing old pistons? Is it a different in pockets being oval or round? Or just higher edges? What kind of pockets does the new pistons have, maybe can figure out what heads will work from there. Iíve only built s few but havnt swapped parts around to know what works. Main difference Iíve seen is oval and round, and thinking as long as you got matching heads you should be ok.
    Jul 2007
    I had oval splash ports. New pistons are dome with round splash port I looked everywhere I can in Promarines book. One area I found suggests a 9100 the other says the 7500. I’m going to call them in the morning, but I’ve had a hard time getting technical info from them.
    Jul 2007
    Trying to put a few pics on
    Jul 2007
    May 2014
    I’ve had good look with help from them. Give them a call, the 9100 do show to be oval. If they help ya out on swapping pistons, I would probably go that route to keep from having a chain reaction of issues by swapping heads. Unless someone who has been there done that chimes in and all transfers flawlessly.
    Feb 2014
    Missouri
    You did order port and starboard not just 6 of one side? Or they might be getting the side wrong if they haven’t done many.
  12. #12
    Jul 2007
    I ordered 3 of each yes. One thing we can’t figure out is it has steel reed pedals and flat pistons. I’m sure about the model number and have checked the head of another blown power head and it’s the same. Is there a chance I don’t have a pro xs, or did they put flat pistons in pro xs in 2008?
  13. #13
    Jul 2007
    Chazz at Promarine?
  14. #14
    May 2014
    Chaz is a 3.0 liter guru on here. Hopefully ole Unc ‘ll chime in and enlighten us
  15. #15
    Jul 2007
    I called mercury and they tell me that it’s not a pro xs. It’s a regular 3.0 opti. Now I’m trying to figure out if I can get pro heads and make it work.
  1. 1999 200 optimax or 2004 250 xs optimax?
    By vmax80096 in forum Technical Discussion
    Last Post: 07-26-2018, 12:34 PM
  2. Mercury Tech: Optimax to non Optimax lower
    By btown101 in forum Technical Discussion
    Last Post: 07-11-2018, 01:41 PM
  3. Will 225 Optimax ECU on my 200 Optimax give it more HP?
    By paragod in forum Technical Discussion
    Last Post: 11-27-2017, 05:18 AM
  4. Optimax 350
    By helios2001ve in forum General Boating Discussion
    Last Post: 08-28-2008, 01:24 PM
Eddie Marine - Horizontal
