Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
    TX......somewhere?
    Quote Originally Posted by dtmeeks View Post
    When I separated it the old one tore so I replaced it. It appeared to match but I'm wonderin if there were maybe some differences in hole sizes I didn't catch. I'm honestly thinking about going to a 1 piece plate and modifying it so I can control the flow.
    there is also a very slight difference in tha 2.0 and 2.4 PH gasket.. on each side of tha exhaust holes one will have 2 small holes and tha other will have 3.. doubt if this makes any difference though...
    with a one piece ya may/may not need ta do a lot "adjustin'" with flow ta get temps right.. may involve pullin' PH a few times doin' this... but then again ya MIGHT get it right tha very first time... patience/testin' is key with it.. jmo.
  2. #17
    Mar 2009
    Hot Springs, AR
    Once I get the 1 piece cleaned up I'm gonna do something studying on it compared to another 2 piece I have and try to get some more info.
    92 Mirage Ski Racer
    86 Laser LTV Bass
    82 Hydrostream Vandal Comp
    ^(project that needs a new home)
  3. #18
    I build these for a living , when you stray from the OEM cooling systems problems follow , others may disagree I could care less ... These Mercury engineers that design these didn’t fall from a logging truck ... When you start straying from OEM cooling I find trouble follows ,
    Good luck , call and I’ll explain !
    Jay 832 597 2603
    Jay @ JSRE
  4. Likes Dave Strong liked this post
  5. #19
    Mar 2009
    Hot Springs, AR
    Thanks for the info Jay. I'll save that 1 piece adapter for another project
    92 Mirage Ski Racer
    86 Laser LTV Bass
  1. Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
    By tristanlee85 in forum Technical Discussion
    Last Post: 07-02-2018, 10:59 PM
  2. Water Pressure/Flow on 94 200 merc...
    By Northerndoc in forum Technical Discussion
    Last Post: 09-19-2013, 07:43 PM
  3. OMC Tech: No water pressure/flow
    By Sum0n3 in forum Technical Discussion
    Last Post: 04-29-2009, 08:34 PM
  4. No water pressure (or flow) on 2.5/260hp EFI (???)
    By Pachanga_rick in forum Technical Discussion
    Last Post: 05-29-2008, 12:01 PM
  5. No water pressure/flow 95 2.5 260efi ?
    By bullet2five in forum Technical Discussion
    Last Post: 07-06-2005, 08:21 AM
