Results 1 to 4 of 4
07-12-2019, 10:37 PM #1Junior Member
- Nov 2018
- MN
- 21
How to remove a 1991 or so QuickSilver Remote Throttle
My trim switch seems to be going bad, it's way too sensitive and has a lot of play in it.
I've removed the plastic center cap, not sure what to do next, I can't seem to get socket to grab on in the center to remove that.
I also put the throttle in full forward position and I see there is a slot and an opening, however not sure how to remove that set screw if there is one there, it seems to be blocked by a red wire and the way my throttle is positioned between the hull and the seat, it's tough to get a good look in there.
I have attached a photo of my remote throttle with the center cap removed.
Thanks,
Jon
07-31-2019, 06:54 PM #2Junior Member
- Nov 2018
- MN
- 21
Since nobody on here chimed in on this, I'm going to try again to track down my manual.
I'm hoping it has the spec on the set screw and/or how to remove this damn thing, so I can replace the Trim button.
08-04-2019, 04:08 AM #3
08-05-2019, 10:08 PM #4Junior Member
- Nov 2018
- MN
- 21
Thanks,
I was finally able to get this task completed.
I used a telescoping little mirror to get a better look into the hole, and that gave me a good idea of what size of allen wrench to use. I could also better tell where the red power wire was blocking access to the set screw. I used a long flat blade screwdriver to push the power wire off to the side a bit, and then used a 5/32nd Allen Wrench to get this set screw out!
Jon
New member 1997 Jazz - I want to remove the engine . Do I need to remove jet first?
By hornman in forum Posting Questions and SuggestionsReplies: 0Last Post: 01-03-2013, 01:38 PM -
How do you remove lever on quicksilver 3000 control box
By mragu in forum Technical DiscussionReplies: 7Last Post: 11-05-2007, 07:25 PM
