Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    Dec 2001
    Themmy things are a BBBB when ya pudding a d/s up....I deform emrs.....so they stay.....
  2. #17
    Important little piece to have as Chris stated. You also want to check rubber seal is in good condition or purchase a new one, they are under $10
    I use an shorten old broom handle with one end turned down to the ID of seal to reinstall.
  3. Likes Baker343 liked this post
  4. #18
    TX......somewhere?
    use "red" on it when ya tap it back in.. they are sometimes prone ta pull out when ya pull a gear case and that will bring out a whole lotta bad words when ya go ta put tha gear case back on..... that's why Tux built his "special tool" ...
  5. Likes tux974 liked this post
  6. #19
    ....yes sir many nice words that wife or neighbor ask’s, you ok?...
    A little starting fluid to clean surface and some of that red stuff does wonders...
  7. #20
    54196A6 --CARRIER ASSEMBLY
    Always wondered why it was called that because its a Crank Shaft to Drive shaft Grease seal. I keep two handy all the time. I also use red Loctite around the lip when I install them in the crank. They are notorious for coming loose and dropping if not properly installed or dropping a lower. And definitely a generous supply of a Good grade marine grease applied to the Drive shaft splines before reinstalling the power head or lower.
  8. Likes tux974 liked this post
  9. #21
    Dec 2001
    Good trick Tux......I pull Ph.......like your Idea.
  1. Getting pulled over
    By wired247 in forum The Scream And Fly Lounge
    Last Post: 04-08-2015, 08:27 PM
  2. How To Check Compression on Pulled Powerhead
    By computertamer in forum Technical Discussion
    Last Post: 09-10-2014, 09:06 PM
  3. Replies: 10
    Last Post: 06-13-2011, 07:26 PM
  4. Pulled my motor
    By Meatbasher in forum Technical Discussion
    Last Post: 11-21-2010, 07:41 PM
  5. You know why I pulled you over sir?
    By Capt.Insane-o in forum General Boating Discussion
    Last Post: 07-03-2007, 09:51 AM
