Results 1 to 5 of 5
Thread: 300x Outboard
07-12-2019, 09:37 AM #1Junior Member
- Apr 2019
- Fort Lauderdale, FL
- 11
300x Outboard
2002 300x with 25” shaft and torque master lower. The engine has 403 hours, I attached a photo from the computer that was taken on July 3rd. The engine might have 2-3 more hours on it since then. Runs perfectly and is meticulously maintained. It gets cleaned, flushed and sprayed with CRC 6-56 after every use. The block was painted white by the previous owner, but it is an original 300x. You can check the serial number. Asking $9,500 or best offer. You can text me or message me on here. 954-849-5749
07-19-2019, 01:49 AM #25000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
Shes due for a rebuild. Way past that point, something to think about
07-20-2019, 06:16 PM #3Junior Member
- Dec 2016
- Houston tx
Are you hand mixing oil for the motor? Looks like the oil resivor is gone.
07-21-2019, 11:31 PM #4Junior Member
- Apr 2019
- 11
Duro78- The engine was recently serviced from a local/reputable shop here in south Florida. They replaced all the pumps, seals, plugs, removed the oil pump and I think the head gaskets were also replaced. From what I know, it should be solid until about 800 hours. It is running great and I haven’t had a single issue.
Out2passu- yes, I premix the fuel using Quicksilver synthetic.
07-28-2019, 07:53 PM #5Junior Member
- Apr 2019
- 11
I spoke to the mechanic and this is everything that was done this past year.
New fuel pumps , alternator , plugs , impeller , o-rings on heads , poppet valve diverter.
Injectors were serviced.
Compression test- 145 pounds of compression in each cylinder.
mercury 300x with warranty full outboard
By NightHawk in forum Outboard EnginesReplies: 6Last Post: 11-29-2015, 08:47 AM -
Outboard cat 300x's vs 300xs's
By drksuroo in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 4Last Post: 10-12-2015, 09:24 AM -
300x Mercury 2003 outboard engines
By lightingspeed in forum Outboard EnginesReplies: 0Last Post: 10-27-2014, 08:57 AM
