Results 1 to 5 of 5
Thread: 300x Outboard
    Apr 2019
    Fort Lauderdale, FL
    300x Outboard
    2002 300x with 25” shaft and torque master lower. The engine has 403 hours, I attached a photo from the computer that was taken on July 3rd. The engine might have 2-3 more hours on it since then. Runs perfectly and is meticulously maintained. It gets cleaned, flushed and sprayed with CRC 6-56 after every use. The block was painted white by the previous owner, but it is an original 300x. You can check the serial number. Asking $9,500 or best offer. You can text me or message me on here. 954-849-5749
    Attached Thumbnails Attached Thumbnails AC3A788E-2C2B-4BA6-84F6-C345DED2C89F.jpg   09304A02-A807-417A-A90F-D829986C1927.jpg   657E10D7-8022-4EDB-B6FD-16A3485E2F9A.jpg   2F7CC8A0-F037-4EA3-B52E-1EFAEC51BD3C.jpg   BE670B88-D60E-4688-9057-8EA02CD2EA3E.jpg
    Apr 2017
    Pomona ny
    Shes due for a rebuild. Way past that point, something to think about
    Dec 2016
    Houston tx
    Are you hand mixing oil for the motor? Looks like the oil resivor is gone.
    Apr 2019
    Fort Lauderdale, FL
    Duro78- The engine was recently serviced from a local/reputable shop here in south Florida. They replaced all the pumps, seals, plugs, removed the oil pump and I think the head gaskets were also replaced. From what I know, it should be solid until about 800 hours. It is running great and I haven’t had a single issue.
    Out2passu- yes, I premix the fuel using Quicksilver synthetic.
    Apr 2019
    Fort Lauderdale, FL
    I spoke to the mechanic and this is everything that was done this past year.
    New fuel pumps , alternator , plugs , impeller , o-rings on heads , poppet valve diverter.
    Injectors were serviced.
    Compression test- 145 pounds of compression in each cylinder.
  1. mercury 300x with warranty full outboard
    By NightHawk in forum Outboard Engines
    Last Post: 11-29-2015, 08:47 AM
  2. Outboard cat 300x's vs 300xs's
    By drksuroo in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-12-2015, 09:24 AM
  3. 300x Mercury 2003 outboard engines
    By lightingspeed in forum Outboard Engines
    Last Post: 10-27-2014, 08:57 AM
