Results 1 to 3 of 3
    Mass
    Single outboard 24 Carrera Ss7m
    I have a 1980 Carrera SS7M. Im sure a lot of you guys are familier with the hull. It’s a 24x7 hull similar to a 24 pantera . Same lower hull but a raised deck. It probably weighs more than a Pantera and a lot more than a 24 superboat . I think the hull is around 3000 lbs . It is currently a big block bravo boat but it’s empty . I won’t have the time or finances to finish the big block project this year so I was thinking about going with an older single 250 3.0l Merc and see how I like it . Does anybody have any experience setting up a pantera or similar ? I have no idea where I would start with setback or height . From my brief research I think 17” setback ? I probably won’t do this but if I find an engine and bracket for the right price I might try it . I have a lot of the Bravo/ big block parts but if I’m happy with an outboard I’ll run that . My guess is it might run about 50 mph with a 250?
    Dec 2001
    I have 24 SB.... same #### ran 50 mph......454/ 200 merc..... your 3.0 should do min of 50.....ya should be happy w/ the switch.....set the motor high.....on boat the bracket should be high....loking at 5 inches min....
    Mass
    Thanks for the replay Dave , just so I understood you correctly you had a 24 Superboat thAt did 50 mph with a 454, and it also did 50 mph with a 200 outboard? Also what did you mean by 5”? A 5” setback bracket ?
  1. CARRERA 24 SS7M - $2500 (East Islip)
    By noli in forum Ebay Listings and Other Internet Listings
    Last Post: 01-30-2019, 01:18 AM
  2. Mercury Tech: LH Sportmaster on a Single Outboard Boat
    By Tango in forum Technical Discussion
    Last Post: 10-15-2018, 12:34 AM
  3. Single Outboard in Offshore (p-6)
    By mike merola in forum General Boating Discussion
    Last Post: 09-09-2016, 08:23 AM
