Results 1 to 15 of 21
07-11-2019, 01:03 PM #1Junior Member
- Sep 2018
- Pa
- 9
Can this sportjet 240 block be saved?
Can this block be saved? Piston disintegrated rod punched out through side of block. Can it be welded and new sleeve installed or is it too far gone? If it can be repaired anyone have a good shop near eastern pa?
07-11-2019, 01:09 PM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,637
- 606
- 918
- 1698
- 7129
- 3 Post(s)
Chaz can weld and sleeve-hes fixed a lot worse. Next question is how many does he have in front of you.
07-11-2019, 01:21 PM #3Junior Member
- Sep 2018
- Pa
- 9
Thanks Joe, but my next question would have been who is Chaz?
07-11-2019, 06:24 PM #4
A very very clever member here , machinist etc
04-01-2022, 10:13 PM #5Junior Member
- Sep 2018
- Pa
- 9
Finally getting around to doing something with this block. Im in PA, looking for someone who can take care of this block. Closer is better of course for shipping but want it done right so... if you guys can throw me some names and numbers of people who can handle it, would be awesome. Or if someone knows what block could be used to replace it, its second gen with the separate alternator. Thanks in advance.
04-02-2022, 01:13 AM #6
04-02-2022, 06:24 AM #7Junior Member
- Sep 2018
- Pa
- 9
Jet
04-02-2022, 08:47 PM #8
04-03-2022, 01:18 AM #9Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
get a 2.5 150 block and port it ......Save ...... lots of $$$$$$
04-03-2022, 02:15 PM #10Junior Member
- Sep 2018
- Pa
- 9
04-03-2022, 02:51 PM #11
The jet engine has different crank splines. so you will either need to use your crank or build a shaft with standard 2.5 splines.
280's came with alternator's. As did 3.0L engines. Simon Mototrsports had / has a kit to mount an alternator on a standard 2.5 block. Buying an alternator from mercury is ridiculous, they are $99.00 on flee-bay. You could have a local fabricator make / build / install any lugs / bosses / etc. that you will need .. start mocking up your new block .. tackle issues one at a time .. you'll see it will go pretty easy.
04-03-2022, 02:53 PM #12
04-03-2022, 05:13 PM #13Junior Member
- Sep 2018
- Pa
- 9
If im going to all the trouble to have a fabricator add all the mounts i need, hope its right, port it to match and any other differences the 240 has, i might as well just fix the one i have! Not like im in a hurry. Im still exploring options so thank you, but id just rather have my block fixed or get a block that will work with minimal effort.
i also know about the splines, what i did not think about is the option of changing the jet side shaft to outboard splines. I could then mount a 200dfi powerhead. Just have to look at compatibility with boat wiring.
might be easier to just get on chas,s list, or if theres any other reputable shops that could handle block repair.
04-04-2022, 02:17 AM #14Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I have a block...... Less holes.... Send me a Wissky it's yors..............HaHaa Mrfker NO goood.... That be Me......
04-04-2022, 02:26 AM #15Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
240 BLOCK.......hONE A fEW.......dAM LOKES ****....
Mercury 2.5 Sportjet/Promax block
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 0Last Post: 02-12-2015, 07:59 AM -
need help , is my sportjet 175 scrap, or can it be saved
By jetrage in forum Jet Boats, V-Drives and Stern DrivesReplies: 3Last Post: 08-11-2012, 06:54 AM -
By 2fast4mom in forum Technical DiscussionReplies: 24Last Post: 07-18-2004, 07:10 PM -
240 hp Sportjet Block
By hydro-cat in forum Technical DiscussionReplies: 2Last Post: 01-10-2003, 11:37 PM
