Results 16 to 20 of 20
11-19-2019, 08:40 PM #16The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
bead blasting is usually always done at way too high a pressure. its a low pressure process, so that the beads aren't shattered & impreg'ed into the material. people don't realize this, that bead blast aluminum. so...you also need to start with new bead material, not old glass bead material that's already been pulverized as well. man, its been years, but 40 psi comes to mind(?). look it up.
11-23-2019, 10:07 AM #17
I've got a big plastic garbage can that I squirt some Dawn dish washing soap into. As I'm filling it with the garden hose ... the Mrs. pours gallon jugs of hot water in and I let it sit till I can reach in and swish the parts around. Hose them off, give them an lacquer thinner squirt , wire wheel the weld site , preheat the part to 200* and start sewing. I throw a sheetmetal tent over the part when I'm done and let it come back slowly ...
tnelsmn liked this post
11-25-2019, 02:19 AM #18Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I am too old and stupid........wish I could sew.......Nice work Chazz......If you were closer I would want your welding skills......Don't like shipping big items.......so need to find a local welder.....
11-25-2019, 08:07 PM #19
yammahas metals suck to weld full of junk it them. I wont even weld on them anymore
12-01-2019, 11:42 PM #205000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
I'm I NH. I've welded alot of aluminum castings. I find that 4047 filler rod works about the best on dirty castings. If it's a die cast part it's even worse because there's usually a lot of zinc in them. The zinc vaporizes before the aluminum creating alot of porosity. Like the guys have said you need to preheat it and it needs to be really clean. You need to clean the area to be welded with a clean metal rotary burr. Not any sanding or abrasive wheels which implant impurities. You can pretty much tell when you put a torch too it how bad it's going to suck to weld.
Cast Alum welding?
By RIVERRUMMER 70 in forum Technical DiscussionReplies: 18Last Post: 01-16-2018, 08:51 AM -
24' BRT w/Mercury 260-New Hampshire CL
By Spdrcr29 in forum Ebay Listings and Other Internet ListingsReplies: 3Last Post: 12-10-2016, 12:01 PM -
Welding Mercury cast aluminum
By blen in forum Technical DiscussionReplies: 2Last Post: 08-21-2009, 02:32 PM -
New member from New Hampshire
By ajohnson in forum General Boating DiscussionReplies: 11Last Post: 02-02-2008, 01:27 PM -
Welding cast aluminum???????/
By B.Mac in forum Technical DiscussionReplies: 14Last Post: 01-21-2003, 05:47 PM
