Results 16 to 30 of 42
    Overtons only has 23 pitch and above in the $319 S3. Also, I always thought that the S3 was slightly different than the Scorpion but I may be mistaken.
    At one point it was rubber hub versus the Flo-Torq hub, but they have the worst product info/website I've ever seen.
  2. #17
    Jul 2004
    Connecticut
    Correct on the different hub. I also think the rake is slightly different on the S3 versus the Scorpion but for $320 who cares. It's worth a try.
  3. #18
    Feb 2011
    HUDSON, FLORIDA
    IM 99% S3 IS same as scorpion. ive looked at a lot of em. the item # is the same, excluding pitch#
  4. #19
    Quote Originally Posted by KIRCHNER View Post
    It was Rubex S3 (interchangeable hub) and Solas Scorpion (fixed hub) when they came out.
    Available as SOLAS® Brand traditional single piece pressed rubber hub or RUBEX® Brand interchangeable rubber hub boat propellers.
    http://www.solaspropellers.com/index...ducts/products
  5. #20
    Feb 2011
    HUDSON, FLORIDA
    YES i agree, very confusing. now i see a prol4 is different # than a standard l4. pro is a 9577, pic shows a lexor, some show pro on hub.
  6. #21
    Jul 2012
    Winnipeg, Mb
    I have a 27p that I run on my superboat. Its very close to 30p I would call it 29.5. It needs vent holes though. Right now I have 7/8" hole in them but probably need them bigger or two. Little hole that comes in it to small.
    Can you post how you made your vent holes
    thanks
  7. #22
    Quote Originally Posted by wottz View Post
    thanks
    Big drill bit
  8. Thanks wottz thanked for this post
    Likes whipper liked this post
  9. #23
    Jul 2012
    Winnipeg, Mb
    Big drill bit
    LMAO.. let me be a little more specific, how did you know the location on the prop to drill and they would all be in the right/same location on each surface of the prop?
  10. #24
    Feb 2011
    HUDSON, FLORIDA
    PROP comes with 3 small holes, located where you would want pvs holes. i used a power drill with a sharp bit. drilled easy. 3/8 0r 1/2 seem like a good choice. venoms superboat drilled them to 7/8''.
  11. Thanks wottz thanked for this post
  12. #25
    Jul 2012
    Winnipeg, Mb
    Do you guys know the hub part number for a 07 225 pro xs
    thanks
  13. #26
    Feb 2011
    HUDSON, FLORIDA
    thanks
    2.5? std or fat shaft?
  14. #27
    Jul 2012
    Winnipeg, Mb
    3.0 small shaft
  15. #28
    some one borrowed my Solas but Im pretty sure I put a Mercury Flo torque hub in it
  16. Thanks wottz thanked for this post
  17. #29
    I'm 99% sure their literature used to say "or Mercury Flo-Torq" but it's hard to find anything on their site now.
  18. #30
    Feb 2011
    HUDSON, FLORIDA
    # 102 15 SPLINE. LOOK at rubex hub ikts.
  19. Thanks wottz thanked for this post
  1. WTB Solas Scorpion 25
    By Wolfjr in forum Propellers Wanted
    Last Post: 02-10-2019, 07:23 PM
  2. WTB Solas Scorpion 28
    By Finman in forum Propellers Wanted
    Last Post: 11-03-2017, 03:48 AM
  3. Solas Scorpion
    By Walleyehed in forum Props, Setup, and Rigging
    Last Post: 05-27-2016, 02:53 PM
  4. 23p Solas
    By 1fast68 in forum Props, Setup, and Rigging
    Last Post: 11-02-2007, 07:24 PM
