Results 1 to 15 of 22
Thread: Cracked Mazco
    Mar 2009
    Hot Springs, AR
    Cracked Mazco
    Trying to break in a new motor and found this today.
    It's a Mazco RE29.
    Is it salvageable or just a wall ornament?
    92 Mirage Ski Racer
    86 Laser LTV Bass
    82 Hydrostream Vandal Comp
    ^(project that needs a new home)
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    I'd send the pics to them and ask the same question
    mazcoprops.com
    Mar 2009
    Hot Springs, AR
    I called the number on the website and got R&R which I had heard bought mazco. They apparently have sold it and gave me another number but that guy didn't answer so I'll try again tomorrow
    92 Mirage Ski Racer
    86 Laser LTV Bass
    Jul 2002
    Las Vegas, NV
    Luckily you caught it before it slung. Not uncommon with thin/fast wheels that are run surface piercing. The only one I have that has been run for a while and hasn't cracked was a 29p I got new, and had cryo treated before running it. I had Kevin @ R&R/Mazco do the same thing to a new 27p RE-3 before he passed away. Haven't run that one yet, but I bet it has a long life.
    Keith-
    Jun 2018
    Floating around
    It can be welded safely imo but for 50mph'ish use. If your running big numbers, mitigating risks at every opportunity is wise money spent and welding is risky
    Put it on the wall.....
  7. Likes RiverRat71, KIRCHNER, JR IN JAX liked this post
    Dec 2001
    that is why..... I tend to look for old racing lowers.....the prop is not doing the speed.... the lower is.....Bring on ya 34s it is a matter when....prop....walking.... JMO.... and like Shultzs......says...
  9. #8
    Jun 2018
    Floating around
    Hmm interesting, can you explain this better?
  10. #9
    Dec 2001
    no just me and my jmo...
  11. #10
    Central, PA
    If you can't get in touch with anyone over there, see if you have any local prop guys and get their opinion.
  12. #11
    Mar 2009
    Hot Springs, AR
    Quote Originally Posted by Bodhi View Post
    The local guy here is about 45 min away, the wrong way from where I ever go. I talked to him and he said he would look at it but also said it didn't sound likely to be fixable, or at least correctly fixed.
    92 Mirage Ski Racer
    86 Laser LTV Bass
  13. #12
    Pekin, IL
    I have had several welded with very limited success. Obviously the thinner the blade the less likely it will hold up. As hard as it is to lose the money these wheels cost it's much better than losing your boat or worse. Great paper weights.
    Rock
    Team Junk
  14. Likes JR IN JAX liked this post
  15. #13
    Mar 2009
    Hot Springs, AR
    I'd hate to have one come apart at speed. I'm just glad I randomly decided to clean the carbon off this one and caught it. Dont have a lot of hope but I'm still gonna get it looked at before I throw in the towel.
    92 Mirage Ski Racer
    86 Laser LTV Bass
  16. #14
    May 2007
    Citrus County, FL
    Quote Originally Posted by dtmeeks View Post
    It's a Mazco RE29.
    I don't post often but reading this has my hair standing up.
    Advice so far; < 50mph (why run it) and hang it on the wall is spot on.
    I have 3 wheels on my wall of shame.
    Folded the end of an ear on 2 labbed 14.5 x 28's. Found them back on the trailer.
    The BIG one though was when I slung an ear off at the hub (closer than the crack pictured) on my favorite 14.5 x 26 Spinelli while under load out on the lake. Lucky not to have been toasted myself on that occasion.
    Once tucked the trim in running 85+ to pull a left corner (against prop torque) and cracked the mid section above the lower bracket mounts (vibrated like hell) and could have lost the lower OR my cookies on that one too. Repaired it and didn't make a whole summer without signs of a fracture starting along the repair. Several folks speculated on the added alloys Mercury uses in casting the parts not liking pure alum rod used to weld the repair.
    No one I knew when a bunch of us were play racing weekends would run a welded on CLE after skeg damage close to the case either.
    Metal fatigues with stress cycles.
    Welding always creates HAZ (heat effected zones) along both joined parts.
    My rig under the right conditions is true 100mph capable.
    Running higher speeds the wheel/lower unit is your only control point.
    just my opinion, not worth the risk
    1994 hand layed Lazer MTV 18'
    1977 Rayson Craft Flat Bottom 18' FE428 thumper
  17. #15
    May 2001
    Maine
    So in looking at the above posts, is Mazco / R&R still around?
  1. Cracked Sleeve
    By dwboater-fisher in forum Technical Discussion
    Last Post: 06-30-2011, 11:23 PM
  2. This just cracked me up!!
    By stoneman in forum The Scream And Fly Lounge
    Last Post: 02-15-2011, 07:48 PM
  3. STV Cracked Pad
    By Mo River Rat in forum Fiberglass and Composites Discussion
    Last Post: 09-20-2008, 09:52 AM
  4. ET's all they are CRACKED up to be
    By RHODIA669 in forum Props, Setup, and Rigging
    Last Post: 04-13-2007, 04:54 AM
  5. Cracked STV
    By twobudros in forum Fiberglass and Composites Discussion
    Last Post: 12-15-2004, 10:47 AM
