Results 1 to 14 of 14
Thread: pontoon decking
07-10-2019, 11:12 AM #1
pontoon decking
I am having trouble finding 5/8 green treated KDAT plywood in small quantities. I can get full units from several places but can't seem to find someone to sell me a couple sheets. Any help appreciated. Thanks
RockTeam Junk
07-10-2019, 04:15 PM #2
Boulter Marine in massachusets will get you any kind of marine plywood you want - delivered -
https://www.boulterplywood.com/1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
07-10-2019, 04:55 PM #3
Thanks. I will try them in the morning.
RockTeam Junk
07-17-2019, 11:46 AM #45000 RPM
- May 2001
- Conowingo Lake,Md-Summer Astor,Fl.- Winter.
- 225
- 7
Pontoonstuff.com
Jim
00 Playcraft Powertoon 00/200 Optimax
57 Trojan Sea Queen/57 Johnson 35hp
05 J16 Carolina Skiff 93/50 Johnson
86 Harris Pontoon 73/60 Johnson
07-17-2019, 12:05 PM #5
Appreciate everyone's suggestions but Boulter does not carry KDAT and Pontoonstuff has the material but has a 4 sheet minimum at $105 per sheet and I only need 2 sheets so I guess I am still looking. Thanks again.
RockTeam Junk
07-19-2019, 07:16 PM #65000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
Carlson150xs, does your tag mean you have a carlson with a 150xs??? Do you have any pics and information???
07-20-2019, 09:44 AM #7
So what is the advantage to using that $ plywood to regular PT, once on the boat I would think it would dry out quick?
07-20-2019, 10:49 AM #8
Apparently you have not tried working with standard pressure treated plywood fastened to aluminum. Will not stay flat, will not hold glue, and will eat your aluminum. The number one reason is I guarantee my work to last as long as the owner. Other than that I spose it would be OK. The KDAT I have always used is getting real hard to find. It's very similar to high quality marine grade 7 ply. If I was not sooo old I would buy a full unit however at my age I doubt I will ever need it again. You are correct in that it would dry out pretty quick once on boat however only on areas not in direct contact with support rails which is where the most serious damage will occur.
RockTeam Junk
1954bmw thanked for this post
07-20-2019, 11:35 AM #9
Twenty some years ago I used 3/4 PT on my 24 ft. toon, a few days in the Fl. sun... it's kiln-dried
toyomirage02 thanked for this post
07-20-2019, 03:31 PM #10
Rock, have you thought about using an insulating tape barrier between the aluminum beams and the wood?
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
07-20-2019, 04:05 PM #11
I have seen it before and that might solve one issue but you still have to be able to glue down carpet. The big issue on this project is it is not a pontoon so material is going down on aluminum deck so it is full contact which is not going to allow it to dry out very well or quickly. If it was mine I would just carpet over aluminum but the customer wants the plywood in place to help quiet boat. To each his own. Boulter, the first recommendation, sent me samples of their marine ply which is very nice but with the full contact I doubt it would last real long. I thought about sealing material with resin but as soon as someone screws something to floor there goes the integrity of the seal.
I appreciate everyone's input. I will find the material I am confident with or I will pass on the project.
RockTeam Junk
07-20-2019, 08:08 PM #12The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
5/8'' PVC board too expensive I would surmise...
07-21-2019, 08:22 AM #13
I have played with West systems epoxy a little and i would think if you used reg plywood, made all the cuts then soaked it down with unthickened epoxy, then screwed it and went over the screw heads with so epoxy on a foam brush???.
07-21-2019, 09:07 AM #14Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
RSWORDS liked this post
what is wpc decking?
By pavannn in forum General Boating DiscussionReplies: 2Last Post: 11-17-2018, 11:36 AM -
Mercury Tech: Decking a block
By speedinstream in forum Technical DiscussionReplies: 15Last Post: 09-06-2017, 10:38 PM -
Block Decking
By faztbullet in forum Technical DiscussionReplies: 2Last Post: 03-27-2006, 07:10 PM -
Block decking
By sean181 in forum Technical DiscussionReplies: 2Last Post: 12-22-2003, 12:23 PM
