Results 1 to 5 of 5
Thread: water pressure ?
07-09-2019, 04:57 AM #1
water pressure ?
I've read on here and other places for years now that folks cold see a drop in water pressure when stats and/or poppet opens??? guess its something I've missed over all these years.. could someone possibly post a video of a gauge actually "droppin' pressure" when this event happens?.. guess I've been lookin' away from gauge at jus tha right time.. I jus have a hard time seein' a spring operated by rpm pressure droppin.. slowing tha pressure build yes, but an actual drop not so much... video's please.. none of this I saw it crap... make me a believer..
oh yeah.. its gotta show tach at same time....
rock thanked for this post
07-09-2019, 07:07 AM #2
Always assumed it worked like they say but never actually witnessed it. Maybe I am not paying enough attention.
RockTeam Junk
07-09-2019, 09:19 AM #3
07-09-2019, 10:24 AM #45000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Not sure if this will work, but here it is. Lower right gauge, by the throttle. When I hit the gas, the pressure drops. Don't mind the tach not working
https://i.imgur.com/ojIIpZR.mp4
07-09-2019, 10:54 AM #5
jus worked for a coupla seconds and stopped.. can't make it work now... hittin' tha gas like that is not what i'm lookin' for.. stab it at idle then show me where it drops on its way up....
Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
By tristanlee85 in forum Technical DiscussionReplies: 25Last Post: 07-02-2018, 10:59 PM -
Wanted: tach, water speedo, water pressure, voltage,
By capnzee in forum Engines WantedReplies: 0Last Post: 01-12-2014, 05:49 PM -
Tell tale water HOT w/ steam and no water on top of motor @ pressure fitting
By MWB in forum Technical DiscussionReplies: 5Last Post: 08-04-2010, 07:40 PM -
Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
By sasquitch in forum Technical DiscussionReplies: 23Last Post: 07-31-2010, 09:16 PM
