Results 1 to 3 of 3
Thread: Liberator Daytona setup
07-07-2019, 08:24 PM #1New Member
- Oct 2017
- Turks & Caicos IS.
Need help dialing in my new toy..19 Liberator daytonya with a 3.0 250 mercury 10" setback manually jackplate any suggestions on engine height or props i should try. is there anyone out there with similar setup
08-28-2019, 12:50 PM #25000 RPM
- Sep 2017
- ontario
- 716
- 68
- 43
- 73
- 171
There are people around still around but to answer your question I currently have a 26 ET that runs 1-1/2 above the centre tunel running surface on a sporty . Water pressure is 15 or so and experiencing a easy 86 and climbing but it was starting to bobble side to side so your a little heavier I suspect don' know what a 3 litre weighs but I'm heavy as well with 200 xs offhore clamp so im getting heavy was well . So 1 -1/2 above pad and it seems like it's - small and fast - the sponson to sponson Bobble I mentioned not sure if that prop walk or running on the sporty bullet but definitely I'm proved speed wise . So I backed away and another day . So hope it attracts more responses other than just my findings . A PROMAXis bought and going to try that same pitch 26 - acceleration is bold and enough top end hopefully -
08-28-2019, 06:23 PM #3
Go up 1/8 inch at a time and test
Eliminator Daytona setup
By Juggernaut in forum Props, Setup, and RiggingReplies: 0Last Post: 11-29-2008, 12:32 AM -
21' Daytona or 21' Liberator and the ruff stuff
By Sleekster in forum General Boating DiscussionReplies: 22Last Post: 02-03-2003, 01:11 PM -
OMC V8 23' Daytona setup
By coxbros in forum Props, Setup, and RiggingReplies: 1Last Post: 01-04-2003, 09:20 PM
