Results 1 to 6 of 6
Thread: EVINRUDE 200/225 jetting?
07-05-2019, 04:40 PM #1Junior Member
- Apr 2015
- Ponchatoula
- 11
I just up graded my 89' 200 small bore carbs and throttle plates to 89' 225 mid bore carbs. looked up all part numbers and they both have stock jetting.
my 200 had 46 mid, 42 idle and 62d mains
the 225 carbs have 47mids, 34 idle and 62d mains
motor ran perfect before swap and has good compression, now with the 225 carbs it will barley idle in neutral and stalls in gear and it bogs and kills if I give it throttle. if I go wide open from idle it will bog and recover and get on plane but is very sluggish. not sure witch direction to turn.
07-05-2019, 05:17 PM #25000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
Seems like more than just a jetting problem.
Did you do the entire Link-n-sync?
07-05-2019, 05:49 PM #3Junior Member
- Apr 2015
- Ponchatoula
- 11
Yes that's the first thing I did.
07-06-2019, 06:21 AM #4
Did u pull carbs apart and make sure everything spotless?
07-06-2019, 12:51 PM #5Junior Member
- Apr 2015
- Ponchatoula
- 11
Yes sir, and replaced bowl gaskets.
07-06-2019, 03:38 PM #6Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
What do the plugs look like? Could tell you if you are way rich or lean.
OMC Tech: 1986 Evinrude 200STLCDR carb jetting recommendation
By turbogti02 in forum Technical DiscussionReplies: 0Last Post: 09-13-2018, 09:08 PM -
Mercury Tech: wh-22 jetting
By 200valeroyt in forum Technical DiscussionReplies: 8Last Post: 07-10-2009, 11:28 PM -
1992 evinrude 200xp jetting
By v8etr in forum Technical DiscussionReplies: 2Last Post: 06-02-2009, 11:46 AM -
89 EVINRUDE 200HP jetting question's?
By THEFERMANATOR in forum Technical DiscussionReplies: 6Last Post: 06-06-2008, 09:44 PM -
JETTING a 2.4 ???
By Xallison in forum Technical DiscussionReplies: 8Last Post: 03-25-2004, 02:07 PM
