Results 1 to 6 of 6
07-05-2019, 01:52 PM #15000 RPM
- Sep 2009
- Miami
- 357
Converting 2006 25 inch 250XS to 20 inch
Could someone tell me what is needed to convert a 25 inch lower to a 20 inch lower. I am purchasing a 25 inch that has a coupler and 5 inch spacer. Think I need new studs no idea of parts number.
Tom
07-05-2019, 02:19 PM #2
I'm sure you'll get lots of 411 on this but I looked at doing the same thing last year and turned away from the idea. The l/u has to be taken apart to change the main shaft (5" shorter). If the coupler you are referring to is a 5" shaft extension then it's going to be much easier and cheaper. You'll also have a 5" shift extension and a 5" water tube extension in there.
Good luck!\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
07-05-2019, 05:43 PM #3
Not clear if you have a 25 inch with a 5 inch spacer making motor now a 30 inch setup. If it is 25 inch with spacer included i think you just remove the added parts that were put on a 20 inch motor. If it started as a 25 inch. It is not cost effective to buy a complete 20 inch mid for it. Another consideration is if motor started as a 25 inch when new. Motor will be a 5800 rpm pcm. 20 inch 250xs will be 6400 pcm.
07-05-2019, 05:56 PM #45000 RPM
- Sep 2009
- Miami
- 357
Started life as a 20 inch. Added coupler and spacer to make it a 25. Trying to find parts number for stud kit.
Tom
07-05-2019, 08:36 PM #5Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Got studs....
07-13-2019, 08:36 PM #65000 RPM
- Sep 2009
- Miami
- 357
Thanks. I went ahead and picked up locally.
wanted to buy two 250 xs 20 inch motors 2006 or newer with sportys left or right hand
By lakemurray in forum Engines WantedReplies: 1Last Post: 08-12-2015, 10:39 AM -
Converting 20 inch opti to counter rotating
By JMM in forum Technical DiscussionReplies: 2Last Post: 01-13-2012, 07:24 AM -
max RPM of 2006 250xs 25 inch shaft
By skywalker26v in forum Technical DiscussionReplies: 2Last Post: 01-20-2008, 10:16 PM
