Results 1 to 11 of 11
    Aug 2002
    Australia
    Mercury 2.5L CLE Gearbox Bearings.
    Can someone give me the actual bearing company part numbers for all the bearings in a Mercury 2.5L CLE gearbox please.
    shreveport,la
    You’re likely not gonna be able to source them from anywhere but Mercury. They have agreements with suppliers to only sell to Mercury. You might find one that’s similar but it won’t be the same. The OaeM’s are smarter than that
    Erik Kiser
    The only bearing you have to buy oem is the pinion bearing. All the rest are availiable through timken,skf,or IKO. I can PM you the numbers in a day or so.
  4. Likes patchesII liked this post
    Aug 2002
    Australia
    Capt.Insane-o
    Could you pm the bearing part numbers please.
    Thanks.
    Skf number for reverse gear bearingClick image for larger version.
    Aug 2002
    Australia
    Capt.Insane-O
    Have you had a chance to find those bearing part numbers.
    Apr 2016
    new brunswick
    I'm rebuilding a 1.87 sportmaster is the bearing list the same for that one ? if yes can you forward to me as well thank you !
  9. #8
    Aug 2002
    Australia
    I'm still waiting for the bearing part numbers.
    All the bearings should be the same.
    Sportmaster have an extra driveshaft bearing.
  10. #9
    Apr 2016
    new brunswick
    I'll buy the drive shat bearings OEM and use your list on the prop shaft I'll keep an eye out for it thank u
  11. #10
    Aug 2002
    Australia
    Can anyone else help with the bearing part numbers please.
    Thanks.
  12. #11
    Apr 2016
    new brunswick
    go ahead and open your lower unit the bearing #'s for all the taper bearings are stamped on them my forward bearing in my speed master jm205149 cup jm205110 I ordered all the roller bearings from Merc dealer be careful of the inner bearing on the forward gear VERY tricky to remove I fabricated a spanner flange and pressed it out the rest are easy with basic pullers and press
  1. Mercury 2.5L Gearbox Bearings
    By chubsta in forum Technical Discussion
    Last Post: 05-29-2019, 04:47 AM
  2. WTB Mercury MK4 gearbox
    By Gavin Bricker in forum Lower Units
    Last Post: 05-30-2016, 04:41 AM
  3. Mercury Blackmax 150hp Gearbox
    By UK Woody in forum Technical Discussion
    Last Post: 08-21-2006, 07:21 PM
