Results 1 to 15 of 21
07-01-2019, 02:08 PM #15000 RPM
- Sep 2006
- Sweden
- 488
- 14
- 260
- 81
Trim sender part number - Mercury 150 Pro Max ss
I had my new dash hooked up (fuel, trim, tacho, water pressure, and volt) and when testing the trim gauge didn't move... Looked over all wiring and all was according to the Service Manual. Then I removed the canopy on the engine and found there was no trim sender connected to the harness (because there is none).
Need a part number for an OEM Mercury trim sender for my Merc 150 Pro Max ss (15" mid) serial# 0G610057.
RIB Unlimited 600/Merc 150 ProMax ss
Allison SS-2000/Merc 200xs ss
Hydrolift T-17/Merc 200xs ss
07-01-2019, 09:06 PM #2
aeneas thanked for this post
07-01-2019, 09:49 PM #35000 RPM
- Sep 2006
- Sweden
- 488
- 14
- 260
- 81
07-01-2019, 09:53 PM #4
Anytime. Btw sweet looking little motor!
aeneas liked this post
07-01-2019, 11:58 PM #5
tux974 liked this post
07-02-2019, 04:23 AM #6
gotta do like Gordon.. don't think there is one for tha 15"er.....
07-02-2019, 04:28 AM #7
with Gordon and tlwjkw need to order a mechanical kit with dash indicator from Stainless Marine.
07-02-2019, 07:06 AM #85000 RPM
- Sep 2006
- Sweden
- 488
- 14
- 260
- 81
07-02-2019, 07:18 AM #9
and tha part number is?
07-02-2019, 02:52 PM #105000 RPM
- Sep 2006
- Sweden
- 488
- 14
- 260
- 81
07-02-2019, 03:13 PM #11
if that works it would be good ta know... not anywhere close ta being listed for a hot rod..
07-02-2019, 03:15 PM #125000 RPM
- Sep 2006
- Sweden
- 488
- 14
- 260
- 81
I'll let you know.
07-02-2019, 06:18 PM #13
I just took a photo of each side of the swivel bracket and see that your SS has different bosses. Mine is a 1999 model and it neither has the clearance for the sender or the mounting holes. As you see in the photos, there are tilt locks on each side that will not clear any sender parts.
I really thought these were all the same...Gordon
07-02-2019, 07:43 PM #14after a little diggin' there's a couple different ones shown on tha "offshore" clamp.. 86485A 5 (early models), 841198A 1 (later models)
"0" for tha shorty PM...
07-03-2019, 05:12 AM #15
If what you have is an OEM 15" (hard to tell from that close up picture) they do not have trim sender built in. Maybe someone cut a 20" swivel section or something else.
The picture you show in post 8 is the end of ram head pin nut.
tlwjkw liked this post
relay number for 225 pro max trim and tilt part number?????
By bill mason in forum Technical DiscussionReplies: 2Last Post: 02-07-2019, 06:43 AM -
omc temp sender part number
By panther150 in forum Technical DiscussionReplies: 2Last Post: 06-22-2010, 10:00 AM -
Mercury 15" short trim ram part number?
By Marcus in forum Technical DiscussionReplies: 2Last Post: 09-15-2004, 01:26 AM
