Results 1 to 15 of 16
07-01-2019, 08:39 AM #1Junior Member
- Mar 2011
- Down South
- 18
Prop Slippage.......fact or fiction
Lately I've been playing with Mercury's Prop Slippage Calculator online and using some of the numbers (RPM and GPS speed) posted by some of the members on S&F, I'm amazed. Plugging in the prop pitch, rpm, gear ratio and posted speed in the Calculator, I'm getting zero % slippage and a couple of cases got 1% slippage. These are single engines on performance boats but can this be possible......zero slippage?
Hopefully someone will share with me their real world experience on this subject. My personal knowledge is with mainly bass boats, V hulls and heavy and I have never seen such low slippage numbers like these on my boats.
07-01-2019, 08:44 AM #2Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-01-2019, 08:45 AM #35000 RPM
- Jul 2008
- Canada
- 112
Depending if the prop is actually the pitch stated and if it has been worked... eg extra cup etc can have an effect on the actually pitch of the prop. And throw numbers off.
07-01-2019, 08:49 AM #4
Highly unlikely the actual slip is that low. What it’s probably telling you is the stamped pitch is not accurate. With the progressive pitch and tip cupping being used these days the effective pitch can vary by as much as 10%. It sounds like the boats you are using data from are pretty well dialed in so if you want to calculate the effective pitch leave the pitch field blank and put 5% in the slip field then calculate pitch. Even then it’s generous as it takes a nearly perfect prop and setup to achieve true 5% slip.
Mark
KIRCHNER liked this post
07-01-2019, 08:49 AM #5Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,643
- 606
- 922
- 1698
- 7144
- 3 Post(s)
Does not happen on a single. Very efficient twin cats will get down there but it happens with guys that work their set up death and spend big money on propellers. Then the other side of the coin is exactly what Mark said-most guys don't know what propeller they really have.
07-01-2019, 09:02 AM #6Junior Member
- Mar 2011
- Down South
- 18
07-01-2019, 09:10 AM #7Junior Member
- Mar 2011
- Down South
- 18
My Skeeter bass boat with a 200 Yami 4 stroke with factory prop calculates at 6% slippage which is about what others are getting with the same rig.
07-01-2019, 10:30 AM #8Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I have to also add sometimes people exaggerate some. It comes with the territory.
07-01-2019, 02:49 PM #9
And... tach RPM could be wrong too. Most tachs have a +/-%. According to my Rinda software on my 496HO the tach was 150 RPM high which will change slip calculations too! It should of set off the guardian BEEPING!
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
07-01-2019, 05:59 PM #10
Prop slip calculation is a great way to compare different setups on your boat, but it's not as good when trying to compare different boats and setups. Differences in tach readings, inaccuracy in propeller pitch measurement, and even the inaccuracies of gps speedometer measures can confuse the comparison of slip % between boat setups. For example, tachometer readings are often inaccurate unless well calibrated.
0% slip is unlikely in real applications.
Here's an article on 'Prop Slip' that may be of interest.Last edited by Jimboat; 07-01-2019 at 06:50 PM.
07-01-2019, 09:52 PM #116000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
If you’re actually flying it will really throw prop slip out of wack. Some of the persons here have less then 6” of pad in contact with the water with no lip on it.
you also have weird effects from the prop at engine rpm over 7k.Last edited by Motv18; 07-01-2019 at 09:56 PM.
07-02-2019, 07:25 AM #12Junior Member
- Mar 2011
- Down South
- 18
Jimboat thanked for this post
07-02-2019, 12:09 PM #135000 RPM
- Jul 2004
- ontario
- 182
- 18
- 59
- 24
Yes pitch stampings can be inaccurate. Solus Scorpion all run near zero or even into the negative. I'm not sure why but I have three of them and they all run 2" bigger than advertised.
07-02-2019, 10:09 PM #146000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Solas rubex sane company make some heavy heavy heavy cup in their props. A hr-4 will turn 3-5% even on my boat where a laser2 runs 8-15 depending on load
07-31-2019, 10:57 AM #156000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
After reading extensive technical pages on prop slip, its impossible to get a true number. progressive prop design. rpm, mfg # rating all contribute to BOGUS slip #. just because u come up with a super low # doesnt mean your at optimun efficiency. some super hp big dollar record setting riggs come up with 17-20 slip figure!? its such a variable i wouldnt loose much sleep over it. my personal boat shows less than 0 slip. which is impossible.
Here's a good one! FACT OR FICTION???????????
By tlwjkw in forum Technical DiscussionReplies: 18Last Post: 08-04-2019, 10:53 PM -
Flooded floors require professional cleanup..... fact or fiction???
By Raceman in forum The Scream And Fly LoungeReplies: 52Last Post: 09-15-2009, 09:27 PM -
GM Fact and Fiction web site! READ learn something!
By The Big Al in forum The Scream And Fly LoungeReplies: 17Last Post: 11-17-2008, 01:14 PM -
Fact or Fiction?
By BUZZIN' DOZEN in forum General Boating DiscussionReplies: 6Last Post: 11-25-2006, 08:41 PM -
prop slippage
By astro1800 in forum Props, Setup, and RiggingReplies: 14Last Post: 05-05-2005, 05:44 AM
