Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 63
    PARADISE /Naples
    The only thing top heavy is the driver
    Now get your sawzall cut open the deck 12 to 18" and move the driver forward.
  2. #17
    Rhode Island
    Yes - I think I'm going to grab a few bags of sand and throw them up front. Maybe 200lbs and see what she does.
  3. #18
    Rhode Island
    Quote Originally Posted by CUDA View Post
    Don't tempt me! haha. I'm THIS close to removing the gas tank in back, and doing something up forward, but it will be a smaller tank for sure. Not much room up there. Just getting the battery up there was a pain in the arse. Right now I have an 18 gallon tank in the rear hatch. I don't think that's helping anything.
    I'll run the tank low, and throw some sandbags up front. Maybe i'll do a fuel bladder type system. That's about the only way I could get a tank up there.
  4. #19
    Oct 2017
    Hugo, MN
    Quote Originally Posted by home made tunnel View Post
    I think 200lb is probably too much, especially if you move them way up front. Start with less and add more as needed.
    Maybe don't have to change or move fuel tank, just don't fill it up all the way. Wouldn't want the tank up front anyway as your balance and hop would always be changing depending on how much fuel you've burned.
    Oh the fun of custom design/rigging.
  5. #20
    Oct 2017
    Hugo, MN
    I bought this bag recently to use for ballast for my side-steer Viking:
    https://smile.amazon.com/dp/B0752S2F...roduct_details
    It fits a 50lb playsand bag from Ace hardware perfectly. The bag of playsand is brick shaped so doesn't roll around.
    Has been great so far.
  6. #21
    Oct 2009
    Lake Conroe, Tx
    Something you could try is put the boat in a slight left arc and see if it stays planted. On mine i did that untill i fixed it. My problem was the center pod was too high, even with the sponsons. I know yours is a true tunnel but maybe engine height, if not weight distribution is probably the issue. The weight up front should tell you some things, and you can fix it from there. Good luck.
  7. #22
    Aug 2012
    Tenkiller Lake, OK
    200# is definitely too much! When in real rough water, I.E. LOTO, I add 70# up front in my 28 Skater. Works well.
  8. #23
    PARADISE /Naples
    That's an idea, Hydrostream would have a small ramp near transom to push down front.
    Try easy stuff first.
  9. Likes home made tunnel liked this post
  10. #24
    You might want to consider Jim Russell's Tunnelboat Design program before you start moving fuel tanks and cutting up your hull. It takes a little time to enter all your weights & dimensions in... but after that you can try any changes you want and see the results in seconds.
    https://aeromarineresearch.com/tbdp6.html
  11. Likes Jimboat liked this post
  12. #25
    Rhode Island
    WOW!!! $400 for the program!!! I'd consider it if it was like $40, but dang that's a price gouge for a computer program.
    I'm going to try the sand bags this week first.
  13. #26
    Rhode Island
    That's an idea that Hydrostream would have a small ramp new transom to push down front.
    Thy easy stuff first.
    Don't they call this "Hook" ? I thought most guys eliminate the hook when re-doing their boats?
    Mine has a pad on the bottom of each sponson, but they're flat.
  14. #27
    A lot or people do eliminate the hook and end up with a porpoise....That you can't ride. Tunnels typically use compression of the tunnel itself to accomplish the same thing. To provide stern lift.
    $400 is a bargain, but you can do it the hard way, too. LOL
  16. #29
    PARADISE /Naples
    I'm just talking about making a 3/16 high 1 inch wide strip of Bondo at the end of the running surface / sponson. easy to sand off or lower if too much.
    Allison's use a low lip
  17. Likes XstreamVking liked this post
  18. #30
    Rhode Island
    You buy it, i'll give you all my measurements LOL :^P
    I'm a single income family man over here saving to build a house next year for wifey and 2 daughters haha.
  1. Video running in the Gulf. 13" tunnel hull
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 10-19-2011, 01:09 AM
  2. New Tunnel design Spire Tunnel hull 126+ with twins
    By whipper in forum General Boating Discussion
    Last Post: 10-10-2011, 04:01 PM
  3. THE tunnel hull video
    By Mark75H in forum Outboard and Racing History
    Last Post: 03-08-2010, 01:11 PM
  4. Prop advice...300x on a heavy hull
    By 86 apache 22 in forum Technical Discussion
    Last Post: 05-22-2007, 12:36 PM
  5. seting up a small but "heavy" tunnel hull
    By 150aintenuff in forum Props, Setup, and Rigging
    Last Post: 05-04-2005, 05:13 PM
