Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 63
    Rhode Island
    Top Heavy Tunnel Hull ? -Video-
    How fast? I don’t know haha. I can’t hold my phone gps at the same time as holding the wheel when she’s about to barrel roll haha. But going slower, When it’s showing 35mph on the vesselview via the paddle wheel input, my gps shows 40mph. So it’s def reading at least 5mph slow.
    So at 60mph indicated on the vessel view, (maybe 65 tru mph?) She starts to porpoise. If I try to drive through the porpoise, trim up or neutral, she starts to jump out of the water! Then prop walks and gets almost into a barrel roll haha.
    I learned about tunnel skirts on this website- wondering if that would help.
    Move already relocated the battery to the front, I think the next is also moving the gas tank forward.
    I have a through-hub 23 cleaver on it right now. I’ve got a 24 over-hub cleaver coming in the mail from a s&f member to try next.
    Prop shaft currently is about 2” above the pads. It hopped worse with the motor lower.
    Taking recommendations for what to try next.
    just need a hull stretcher. that's all.
    please install and USE an ignition kill switch, if you haven't already.
  4. Likes FMP liked this post
    Rhode Island
    Haha hull stretcher would definitely work! Hahaha
    and I absolutely have an ignition kill switch, wrapped around my ankle, goes to the dash.
    Ha! , short trees
    Ontario, Canada
  8. Likes David - WI liked this post
    Cut about 5" out of the midsection.
  10. Likes FMP liked this post
    Tunnel needs more compression. Bow is flying hi, tunnel hulls need to run flat.
    I live in Prineville Oregon which is in the central part of the state
    Tunnel hull hop.
    What type of prop are you running on this rig. I have had many old school type tunnels hulls in my life and think I know a thing or three about how they perform. Please provide a picture of your prop from the rear and I will bet that I can help you with this problem or give me a call at 541 570 0955 out here in Oregon.
    Best wishes, Carter Powell
  13. Likes XstreamVking liked this post
    Try a tuck in and raise motor more. My Flatty has a pad, and 1 inch drop chines and like a tuck in or will porpoise. 15.6 foot, 330 lb Merc, SS2 blade too"
  15. Likes home made tunnel liked this post
  16. #11
    Too much weight on the end of that pendulum
  17. Likes Robby321, JBS, KIRCHNER liked this post
  18. #12
    Dec 2006
    Mt. Laurel, N.J.
    I assume you are using a hull pickup with a stock lower?
    Azure AZ259, 8.1
  19. #13
    Quote Originally Posted by gotboostedvr6 View Post
    I think we (no offense OP, been there young, I'm 69 now)) but .."this should work!" is a learning lesson simple! There ARE limits but "he's wrong, young and simple young says .."! Oh really?
    Still in force today! (And may the 4TH be with you
    Newton's three laws of motion may be stated as follows: Every object in a state of uniform motion will remain in that state of motion unless an external force acts on it. Force equals mass times acceleration [ ]. For every action there is an equal and opposite reaction.
  20. #14
    Rhode Island
    Quote Originally Posted by Carter Powell View Post
    Quote Originally Posted by Robby321 View Post
ID:	443496Click image for larger version.
ID:	443497 23 pitch, through hub cleaver. I've got a 24 pitch over hub cleaver that just came in the mail. I can't tuck the motor much anymore - but I can go a little higher. And, FYI, it's an optical illusion that the pads aren't level. They are dead nuts level, checked with straight edge.
  21. #15
    Jul 2001
    Paris, France
    I'd try a few 10lb sandbags at the front
    ARGO Cat 18'
    Mercury 2.4EFI/CLE
    If it's not a cat it's a.............dog ?
  1. Video running in the Gulf. 13" tunnel hull
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 10-19-2011, 01:09 AM
  2. New Tunnel design Spire Tunnel hull 126+ with twins
    By whipper in forum General Boating Discussion
    Last Post: 10-10-2011, 04:01 PM
  3. THE tunnel hull video
    By Mark75H in forum Outboard and Racing History
    Last Post: 03-08-2010, 01:11 PM
  4. Prop advice...300x on a heavy hull
    By 86 apache 22 in forum Technical Discussion
    Last Post: 05-22-2007, 12:36 PM
  5. seting up a small but "heavy" tunnel hull
    By 150aintenuff in forum Props, Setup, and Rigging
    Last Post: 05-04-2005, 05:13 PM
