Results 1 to 4 of 4
    May 2018
    Miami
    20.1 1994 Eliminator Stoker Sport Tunnel
    My 20.1' 1994 Eliminator Stoker Sport Tunnel is for sale.
    Boat itself has Original Gel Coat in Excellent condition, updated interior with customer Stoker Logo stitched in, Livorsi Tattle-Tale GPS Speedo , Digital Tach, all working gauges. Newly installed Fusion Marine System with 4 Channel Fusion Amp, Bluetooth Controller , 2 6.5" Fusions, & 2 6" Fusions in the gunnels. Boat does have stress cracks in usual place, nothing severe.
    Motor is a (I believe) 1994 Evinrude 225 that has had some work done to it from previous owner. It is a very healthy motor with 140 Compression on all 6 Cylinders. Johns Custom Marine (Al Stoker) Heads and Intake. I was told from owners son to run only 100LL gas on it and thats the only gas used on it. Owner's son stated that this motor made approx. 315-325HP according to the dyno sheet he had. Unfortunately this sheet was misplaced by him but I am considering getting this motor dyno'd to have ACTUAL numbers. A complete tune up has been done to the boat with all filters,carburetors rebuilt, spark plugs, choke valve seal, jack plate relays and starter replaced. Both steering cables were also replaced as well as a New Interstate Battery was put in. A 25P Shooter Prop from Bronson Propellers will come with the boat. Carburetors were just rebuilt as well as shifter and throttle cables replaced new.
    Trailer is made by Extreme Custom Trailers. Hydraulic Braking with a Pivit Hitch up front. LED Lights in the rear.
    Extras; Also comes with Shop manual for motor, skiing equipment , miscellaneous (Oils, Lower Unit Gear Oil, ETC.)
    Boxes & receipts for everything that has been done to it can be given upon request.
    According the owners son his father was diagnosed in 2005 with a terminal illness and never took the boat out of storage since then. Boat has less than 100 hours. I have owned the boat since October and have taken meticulously good care of it. After going through and doing a complete tune up of everything after finding some odds & ends that needed to be replaced, this boat is in excellent shape and has been taken great care of. With me as the owner, it has touched the water twice with less than 8 hours combined and has never been beaten up. I am asking $14,500 or best offer. If you have any questions or concerns feel free to PM me to get in contact with directly.
    Since pictures were taken new throttle and shifter cables have been installed as well as a new Holley Red Fuel Pump.
    Boat is located in Miami FL
ID:	443153Click image for larger version.
ID:	443154Click image for larger version.
ID:	443155Click image for larger version.
ID:	443156Click image for larger version.
ID:	443157Click image for larger version.
ID:	443158Click image for larger version.
ID:	443159Click image for larger version.
ID:	443161Click image for larger version.
ID:	443162Click image for larger version.
ID:	443163Click image for larger version.
ID:	443164Click image for larger version.
ID:	443165Click image for larger version.
ID:	443167Click image for larger version.
ID:	443168Click image for larger version.
ID:	443169Click image for larger version.
ID:	443170Click image for larger version.
ID:	443171Click image for larger version.
ID:	443173Click image for larger version.
ID:	443174Click image for larger version.
  2. Likes LAAllison liked this post
    Nov 2018
    New Baltimore Michigan
    That is one Beautyful boat !
    May 2018
    Miami
    Bump
    May 2018
    Miami
    BTTT
    Make me an offer! Need sold ASAP taking up room.
  1. 20.1 Eliminator Stoker Sport Tunnel
    By breezly in forum Hulls larger than 20'
    Last Post: 09-25-2019, 10:10 AM
  2. 1988 Eliminator Stoker Sport Tunnel 20’ w/ Mercury 200
    By breezly in forum Hulls up to 20'
    Last Post: 11-29-2018, 11:47 AM
  3. 1987 eliminator / stoker V tunnel need help with set abd mods
    By vt200rocket in forum Props, Setup, and Rigging
    Last Post: 06-08-2016, 10:38 AM
  4. Stoker Sport Tunnel 20 SST
    By tgreen in forum Hulls Wanted
    Last Post: 01-25-2016, 11:36 PM
  5. Stoker Sport Tunnel 20.4
    By Forgiven in forum Hulls larger than 20'
    Last Post: 09-04-2015, 05:43 AM
