Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 86
    Jul 2011
    Gloucester, VA
    Late model downdraft 225 Efi 3 liter stage by stage build up
    This thread will be to document my build up of a 3 liter with the 555 Motorola ECM. Its going to eventually go on my hydrostream but until then I'm going to use it on my 25' C-Hawk to for testing. Right now the boat is running an old 225 carb powerhead converted to 250 4 butterfly intake with the twin computers, and a 300 on box. Its seen a best of 44mph.
    I want to use this powerhead we are building up for a race this fall and to test it before it goes on the hydrostream. If I do something wrong and it eats itself on the chawk at WOT I get towed home.... on the stream I get wet.
    The first stage is going to be Chris Carson reeds and stuffers. I've used his reeds in all my motors and countless customer motors with great success. This will be my first time with the stuffer though. I'm also considering stripping the cages and using his reeds for that. Thoughts from anyone?
    Also in this first Stage Chaz will be cutting my heads to tighten the motor up some. Going to keep it 93 octane friendly for the moment.
    Starting with a low hour motor I went ahead and pulled the heads to send to Chaz. Only broke three head studs, not bad. Two came out with some vice grips and heat the third I'll end up drilling.
  2. Likes Great East Predictor liked this post
    Jul 2011
    Gloucester, VA
    Got Chaz the measurements he needed to figure out where to cut the heads. No compression relief notches and 45.5mm height. He seemed really excited by this. he has said he will chime in to help with some of the tech and reasoning for the route we are taking.
    Jul 2011
    Gloucester, VA
    Stage 1.5 will be a swap to a 250ecm
    Stage 2 will be a lightened flywheel and notched CPS for a bit more timing.
    Stage 3 will be one of Chazs billit 300x style intakes with the injectors outside.
  5. Likes Laseraddict liked this post
    Florida Keys
    This should be cool
    '95 STV "The Blue Goose"
  7. Likes Captain75 liked this post
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by mach351 View Post
    This should be cool
    I hope. If nothing else it's a spot for me to keep all my notes and ideas all together with my scattered brain. Case in point. The heads have been boxed up with a shipping label on them for a week and I keep forgetting to drop then off to send to Chazy
    Nov 2009
    hardyville va
    Quote Originally Posted by RSWORDS View Post
    You can re-program your ecm.
    Be careful with the timing advance, I would not mess with it.
    The intakes are the biggest gain, You need to cut the can, but it makes it loud.
    You can easily clean the exhaust area up where blends into the mid, some block work can also be done without removing the liners.
    Good luck with the build.
  10. Likes Laseraddict liked this post
  11. #7
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by cali kid View Post
    I may or may not have a way to flash mine to 300x specs....
    But I definitely have a spare 250 ecu
    Old Charlie should have my heads any day.
  12. #8
    Jul 2011
    Gloucester, VA
    Hopefully.he has a 300x style intake made up....... hint hint....
  13. #9
    Jul 2011
    Gloucester, VA
    Jul 2011
    Gloucester, VA
    Lets talk stripping Reed cages. Best way? Results?
    Looks like stage one is stage 1, 2, 3, combined ...
    The reason I was adamant about ex-port ht is about final "trapped compression" ratio.
    To use round numbers, a 300x has a 1.700 , yours is 1.800
    If we were to cut your heads to 61cc like an X has , we would need to run AV gas or it's equivalent "ALL" the time.
    Cutting them to 64 - 65cc ( from stock 73cc ) will put you right in the same place that a X is stock, @ your port ht.
    Cali .. I disagree with the timing issue. Put a light on a 225/250 and then check a 300x and get back to me.
    I wouldn't get the box tuned-up "and" slot the pick-up eye. It would be a, one or the other thing.
    I slot the eye ( and use allen bolts as hold downs ) because they need all the help they can get off the bottom, and with stock port timing raising the limiter .. is , well ..
    I do agree ... the injectors, harness, fuel rail, bridges and braces don't belong in the plenum ...
    I've got some stock rubber baby buggy bumper reed cages and some stripped cages. I'll measure the window opening of both and post the diff ...
  16. #12
    PS .. Yes the heads made it here ..
    When I seen the size of that box. I said : Girl, cut that box open, he might have sent one of them sweet Virginia hams down here with em ...
    Jul 2011
    Gloucester, VA
    Lol when I send my flywheel I'll see what I can do buddy.
  18. #14
    Chazy????? Old Charlie??????? OMG
  19. Likes RSWORDS liked this post
  20. #15
    Call me whatever ya want ... cept, late fer lunch ...
    I "wuz" savin this fer when you come back .... Hummpfff
  21. Thanks vnemous thanked for this post
  1. SVS for 300x or late model 3.0 with a downdraft intake
    By opsdave in forum Misc. Parts and Accessories
    Last Post: 12-21-2015, 09:24 PM
