Results 1 to 15 of 20
Thread: newbe help 1976 merc 1500 sx
06-28-2019, 11:18 PM #1Junior Member
- Jun 2019
- northern wisconsin
- 16
cool site alot of great info here
i just bought a kinda basket case 74 17' hydrostream vector with a 76 merc 1500 sx
i need a bracket and link arm for the dual cable ride guide steering setup
the motor end only has one tube on it now
cant seem to find one ?
do i need to fab up my own ?
thanks
06-29-2019, 12:13 PM #2
I think it takes a special setup for dual cable on the old inlines. I have the setup for the v6 Mercs if you want to modify the bracket. Are the hole drilled in the front of the mounting bracket to even bolt it on?
06-29-2019, 12:30 PM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
They didn't have holes for the 2nd cable. The 2nd tube went in front and you had to take off the nuts on each end of the tilt tube........
06-29-2019, 04:38 PM #4Junior Member
- Jun 2019
- 16
there are no holes in the transom clamp
i do have a v6 bracket that i can use
thanks for the offer though
just was wondering if some company made one ready to go
or il just use the one i have and make a bracket to hang it off of and in front of the tilt tube
or any other ideas ???or pics of a current set up that works
thanksLast edited by d3k; 06-29-2019 at 04:58 PM.
06-29-2019, 06:53 PM #5
T&R Marine offers old school steering stuff. Might be worth a phone call
06-29-2019, 10:03 PM #6Junior Member
- Jun 2019
- 16
thanks i will give them a call
07-06-2019, 11:05 PM #75000 RPM
- May 2014
- WI
- 126
- 15
- 57
- 60
Here's a picture of the setup I have for an inline 6 merc. I bought the second tube from an inline 6 genius in MN. They are fairly scarce. I don't think people know that, and likely many get thrown out. There is a part number and I have it somewhere, I'll try to find it. I don't believe that the part number was on the tube at all. It's really quite a simple part, so it could be easily fabricated.
As for the tiller arm dual steering link bracket, I actually got that when I bought another boat so I can't help with any part numbers or sources lol
Baker343 liked this post
07-06-2019, 11:56 PM #8
Looks like an old Mercury Dual Ride-Guide connection kit. Lucky you to find it.
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
07-08-2019, 08:33 PM #9Junior Member
- Jun 2019
- 16
had no luck with T&R Marine nice guy tho
thats a cool set up starviper10 thanks for the pic
both of my cables are routed on the starboard side tho
im just gonna make a bracket out of the newer style set up that came with the boat
thanks
starviper10 liked this post
07-09-2019, 09:43 PM #105000 RPM
- May 2014
- WI
- 126
- 15
- 57
- 60
For the linkage arm, I believe you need the one shown in post #10 here:
https://www.screamandfly.com/showthread.php?318457-Ride-guide-link-adapter-260
07-09-2019, 11:11 PM #11Junior Member
- Jun 2019
- 16
thanks again starviper10
that is the stuff i have already
much newer setup
mine is much older the transom clamp is way different
i have no holes in the transom clamp just 2 grease zirk fittings in the tilt tube
i would think merc had to have a set up for this starboard cable style set up
just cant seem to even find a pic of one yet
07-13-2019, 06:04 PM #12The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
on the front of this BP is an original Mercury brand steering tube for a second steering cable. they had a cable coming in from each side. it was called a tension/compression system. one cables link arm was adjusted out against the other until all steering slack or play was eliminated. any of the original, dual cable Mercury steering parts & pieces were called they're "Super Ride-Guide" system parts. Dual racks, extra long gear & bolt at the helm to connect the dual racks, dual cables, the add-on clamp bracket steering tube for the second cable, and the hardware connection parts to connect to the tiller arm with a second steering link arm. hope this helps.
07-13-2019, 07:39 PM #13Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Me seeess a old no/good 135 stacker..... HeHee..... I will give him the part he needs when I get that motor......Just what ever old Merc dealer has in the back room.....He just bet..... fabing what he needs.....
07-13-2019, 11:10 PM #14Junior Member
- Jun 2019
- 16
thanks for the pic and info
good stuff
awesome looking engine
bet that things loud and fast
i have the same engine stands
got the materials to make my bracket tomorrow
finally have a day off and some free time
thanks for everyone's help
07-18-2019, 10:55 AM #15Member
- Oct 2007
- 88
- 10
- 31
- 48
1976 Merc 1500 Shorty
By Tom Smyth in forum Outboard EnginesReplies: 21Last Post: 04-30-2019, 06:40 PM -
1976 1500 inline 6 prop HP?
By KG4 in forum General Boating DiscussionReplies: 5Last Post: 04-19-2019, 05:36 PM -
1976 1500 gear ratio
By Chuck Mostaka in forum Props, Setup, and RiggingReplies: 4Last Post: 11-26-2007, 05:29 PM -
1976 1500 Mercury
By Mickdund in forum Outboard and Racing HistoryReplies: 3Last Post: 07-24-2002, 02:02 PM
