Results 1 to 15 of 20
    Jun 2019
    northern wisconsin
    newbe help 1976 merc 1500 sx
    cool site alot of great info here
    i just bought a kinda basket case 74 17' hydrostream vector with a 76 merc 1500 sx
    i need a bracket and link arm for the dual cable ride guide steering setup
    the motor end only has one tube on it now
    cant seem to find one ?
    do i need to fab up my own ?
    thanks
    May 2002
    Harriman, TN
    I think it takes a special setup for dual cable on the old inlines. I have the setup for the v6 Mercs if you want to modify the bracket. Are the hole drilled in the front of the mounting bracket to even bolt it on?
    Dec 2001
    They didn't have holes for the 2nd cable. The 2nd tube went in front and you had to take off the nuts on each end of the tilt tube........
    Jun 2019
    northern wisconsin
    there are no holes in the transom clamp
    i do have a v6 bracket that i can use
    thanks for the offer though
    just was wondering if some company made one ready to go
    or il just use the one i have and make a bracket to hang it off of and in front of the tilt tube
    or any other ideas ???or pics of a current set up that works
    thanks
    May 2013
    Huntiington Beach Ca
    T&R Marine offers old school steering stuff. Might be worth a phone call
    Jun 2019
    northern wisconsin
    thanks i will give them a call
    May 2014
    WI
    Here's a picture of the setup I have for an inline 6 merc. I bought the second tube from an inline 6 genius in MN. They are fairly scarce. I don't think people know that, and likely many get thrown out. There is a part number and I have it somewhere, I'll try to find it. I don't believe that the part number was on the tube at all. It's really quite a simple part, so it could be easily fabricated.
    As for the tiller arm dual steering link bracket, I actually got that when I bought another boat so I can't help with any part numbers or sources lol
  8. Likes Baker343 liked this post
  9. #8
    Nov 2003
    Portsmouth VA
    Looks like an old Mercury Dual Ride-Guide connection kit. Lucky you to find it.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  10. #9
    Jun 2019
    northern wisconsin
    had no luck with T&R Marine nice guy tho
    thats a cool set up starviper10 thanks for the pic
    both of my cables are routed on the starboard side tho
    im just gonna make a bracket out of the newer style set up that came with the boat
    thanks
  11. Likes starviper10 liked this post
    May 2014
    WI
    For the linkage arm, I believe you need the one shown in post #10 here:
    https://www.screamandfly.com/showthread.php?318457-Ride-guide-link-adapter-260
    Jun 2019
    northern wisconsin
    thanks again starviper10
    that is the stuff i have already
    much newer setup
    mine is much older the transom clamp is way different
    i have no holes in the transom clamp just 2 grease zirk fittings in the tilt tube
    i would think merc had to have a set up for this starboard cable style set up
    just cant seem to even find a pic of one yet
  14. #12
    on the front of this BP is an original Mercury brand steering tube for a second steering cable. they had a cable coming in from each side. it was called a tension/compression system. one cables link arm was adjusted out against the other until all steering slack or play was eliminated. any of the original, dual cable Mercury steering parts & pieces were called they're "Super Ride-Guide" system parts. Dual racks, extra long gear & bolt at the helm to connect the dual racks, dual cables, the add-on clamp bracket steering tube for the second cable, and the hardware connection parts to connect to the tiller arm with a second steering link arm. hope this helps.
  15. #13
    Dec 2001
    Me seeess a old no/good 135 stacker..... HeHee..... I will give him the part he needs when I get that motor......Just what ever old Merc dealer has in the back room.....He just bet..... fabing what he needs.....
  16. #14
    Jun 2019
    northern wisconsin
    thanks for the pic and info
    good stuff
    awesome looking engine
    bet that things loud and fast
    i have the same engine stands
    got the materials to make my bracket tomorrow
    finally have a day off and some free time
    thanks for everyone's help
  17. #15
    Oct 2007
    tough to find, here you go if you want to make oneClick image for larger version.
Name:	the new girls 004.jpg
ID:	444645Click image for larger version.
Name:	the new girls 003.jpg
ID:	444646Click image for larger version.
Name:	the new girls 002.jpg
    1964 Chris Craft Holiday
    Homemade Glen-l Crackerbox
    71 Switzer 17 with twin Merc 1350s
  1. 1976 Merc 1500 Shorty
    By Tom Smyth in forum Outboard Engines
    Last Post: 04-30-2019, 06:40 PM
  2. 1976 1500 inline 6 prop HP?
    By KG4 in forum General Boating Discussion
    Last Post: 04-19-2019, 05:36 PM
  3. 1976 1500 gear ratio
    By Chuck Mostaka in forum Props, Setup, and Rigging
    Last Post: 11-26-2007, 05:29 PM
  4. 1976 1500 Mercury
    By Mickdund in forum Outboard and Racing History
    Last Post: 07-24-2002, 02:02 PM
