Results 16 to 30 of 30
07-13-2019, 11:57 AM #16Junior Member
- Jun 2019
- San Diego
- 17
the issue was the female connector in the wiring harness wasn't making good contact on the pins in the CDM. I tightened all the pins up a tad, replaced the spark plug on the cylinder, the plug wire coming off the CDM and away it fired.
XstreamVking liked this post
07-13-2019, 12:00 PM #17
07-13-2019, 12:03 PM #18Junior Member
- Jun 2019
- San Diego
- 17
Thanks, I plan on dropping the boat in the water hopefully this next week and burn some fuel.
07-13-2019, 12:12 PM #19Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Wow a junior mechanic called it.....Had a friend just a few days ago same engine same prob same fix...I guess as these EFI 3.0's get older they need more connector attention.
Dklongbomb liked this post
07-18-2019, 06:46 AM #20Junior Member
- Apr 2016
- turks and caicos
- 18
Im having the same exact problem. What was the cause?
07-19-2019, 06:41 PM #216000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Loose pins,
think of it like a wall wall socket that won’t hold the plug in -> male female instead of -= nice and tite
07-25-2019, 10:36 PM #22Junior Member
- Jun 2019
- San Diego
- 17
Took the boat out this week and ran some fuel through it, ran good for the most part. Have a quick question:
When I started the starboard motor Cold right off the trailer it had one sneeze or backfire right after it fired up but didn’t do it again at all and the motor purred and idled right at 600rpms and hit high rpms. Should I be concerned about anything? I have in line fuel flow monitors and noticed this engine was using less fuel than the port engine per hour. How can you tell if you are running to lean?
A little back ground, I adjusted throttle linkage and roller cam per spec in the manual. I also adjusted the tps to dead on at 3.80 volts at idle.(for some reason my tps is backwards) and rechecked idle.Last edited by Dklongbomb; 07-25-2019 at 10:45 PM.
07-26-2019, 05:31 PM #23Junior Member
- Jun 2019
- San Diego
- 17
07-26-2019, 05:57 PM #24Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Usually a sneeze is caused by a lean condition. Can blow out the pulse fuel pump when it does it.
07-26-2019, 06:18 PM #25Junior Member
- Jun 2019
- San Diego
- 17
07-26-2019, 06:22 PM #26Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
That, i'm not sure about. Most EFI motors don't tend to sneeze.
07-26-2019, 06:29 PM #27Junior Member
- Jun 2019
- San Diego
- 17
07-26-2019, 10:24 PM #286000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Did it die right after, they can stop just after spark and it is a sneeze but only from the engine stopping some of the pressure just came back out the intake.
07-26-2019, 10:30 PM #29Junior Member
- Jun 2019
- San Diego
- 17
07-27-2019, 07:01 AM #306000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Sometimes they happen, misses also happen quite often just because.
Check for damage and carry on, a few in a row or every start that’s a problem.
Mercury firing in 2 cylinders same time
By Davidpkl in forum Technical DiscussionReplies: 14Last Post: 04-27-2016, 07:20 AM -
03, 200 merc?? Not firing need help
By knot<safe77 in forum Technical DiscussionReplies: 5Last Post: 05-11-2013, 12:13 PM -
Merc V200 Not Firing on all cylinders!!
By fmeroney in forum Technical DiscussionReplies: 32Last Post: 06-03-2011, 08:58 PM -
Merc Pro Max 225 firing
By gerry 56 in forum Technical DiscussionReplies: 1Last Post: 06-14-2009, 02:45 PM -
OMC Tech: 3 cylinders not firing
By Hazard in forum Technical DiscussionReplies: 17Last Post: 07-29-2008, 02:49 PM
