Results 1 to 15 of 30
06-25-2019, 09:53 PM #1Junior Member
- Jun 2019
- San Diego
- 17
Merc 250 efi only firing on 5 cylinders
looking for a little help on one of my 1998 merc 250 efi’s. I have a pair of them on the back of my boat one runs great the other is running a bit rough.
Went to do some yearly maintenance, pulled the plugs(champion ql77cc) and found that number 6 cylinder, bottom left was all gummed up and had fresh fuel on it. Turns out it’s not firing after a spark test, I’m getting only 5. The bottom left is the one not firing.
I got a new coil, checked all the grounds, ohm’Ed out the crank position sensor, ohm’ed all the rest of the coil’s, omh’ed out the stator bobbins, checked continuity on the grounds, stater wire, trigger wire, stop wire, swapped the ecm ignition module with the other motor and nothing. Did a compression test and all came it at 115psi.
This one has me stumped, any suggestions? I went through the service manual and performed all the tests under 2A ignition troubleshooting and haven’t been able to find the culprit.
Any suggestions or help would be much appreciated!
06-25-2019, 10:25 PM #2
Gummed up how? black and oily, milkshake goo or carboned up?
06-25-2019, 10:33 PM #3Junior Member
- Jun 2019
- San Diego
- 17
Very black and oil with fresh fuel pretty much dripping off of it. The other five look very consistent and uniform with just carbonation.
06-26-2019, 10:06 AM #4Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Does it have spark on that cylinder?,if yes check the reeds...
06-26-2019, 11:06 AM #5Junior Member
- Jun 2019
- San Diego
- 17
06-26-2019, 11:09 AM #6Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Check the connector pins for that cylinder all the way back into the computer. Just had a 225 efi with an intermittent spark and it was a pin connection problem.
06-26-2019, 11:11 AM #7Junior Member
- Jun 2019
- San Diego
- 17
Ok, will take a look and look into the connection pins/connectors.
06-29-2019, 04:38 PM #8Junior Member
- Jun 2019
- San Diego
- 17
So i took a look at the pins and they all "seem" to be making good contact. Also checked continuity back to the ECM on all the connecting pins.
Something very strange, I hook all the plug wires back up to quicksilver spark test board and as I cranked the engine, I started unplugging the other cylinders off the quicksilver spark tester and all of a sudden #6 started firing. However with all six hooked up it will not fire at the same time. Seems like something is shorting out along with way or it's not getting enough power to fire all the CDM's at once?
Any suggestions?
06-29-2019, 05:03 PM #95000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
they switch between cdms on these motors...no fire on one may mean the cdm it switches with is bad ...pull all the primarys ...hook each back up and test for spark one at the time...see which one doesn't work
06-29-2019, 05:26 PM #106000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
You need to check each cdm individually. A faulty ground on one can drop spark on another.
One of them is bad
06-29-2019, 05:59 PM #11
07-10-2019, 09:52 PM #12Junior Member
- Jun 2019
- San Diego
- 17
After testing the spark on the CDM's individually one by one on my spark tester and cranking the engine over, it looks as if I am getting spark on that cylinder.
After doing a little more testing, I decided to check the volts on me throttle position sensor and I believe I am getting abnormal results. Here are my finding's, I used a digital multi-meter with two wires plugged into the connector, black is on the ground black wire and red is on the blue wire with a red stripe, does this sounds correct?
I am getting 3.80 volts at idle and 2.13 volts at WOT.
I have read in the manual I should be getting .095 +/- .05 at idle and 3.80 at WOT?
Any suggestions? Does anyone think the sensor is shot?Last edited by Dklongbomb; 07-10-2019 at 09:55 PM.
07-10-2019, 10:57 PM #13
07-13-2019, 09:15 AM #14Junior Member
- Jun 2019
- San Diego
- 17
I have figured out the spark issue and is now firing on all 6 cylinders.
The engine is definitely running more smooth at idle. However, if I rev the engine up a couple times and pull back the throttle the engine hesitates and acts like it’s going to die before regaining the idle speed again. Any suggestions? help would much be appreciated.
07-13-2019, 10:35 AM #15Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Howabout you share the spark solution?
XstreamVking liked this post
Mercury firing in 2 cylinders same time
By Davidpkl in forum Technical DiscussionReplies: 14Last Post: 04-27-2016, 07:20 AM -
03, 200 merc?? Not firing need help
By knot<safe77 in forum Technical DiscussionReplies: 5Last Post: 05-11-2013, 12:13 PM -
Merc V200 Not Firing on all cylinders!!
By fmeroney in forum Technical DiscussionReplies: 32Last Post: 06-03-2011, 08:58 PM -
Merc Pro Max 225 firing
By gerry 56 in forum Technical DiscussionReplies: 1Last Post: 06-14-2009, 02:45 PM -
OMC Tech: 3 cylinders not firing
By Hazard in forum Technical DiscussionReplies: 17Last Post: 07-29-2008, 02:49 PM
