Results 1 to 7 of 7
    Western Pennsylvania
    Removing topside hull stains
    Rub rail up, how to remove the spots created by a leaf which leaves a stain. I tried hull cleaner but doesn't work. I can remove with a cleaner/wax with a lot of rubbing... but has to be a better way.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Acetone followed by clear water, try a small test area
    Also adding the flapping bugs by their wings...
    Lindenhurst, NY
    I've used a rag with bleach on it and let it sit for a couple of minutes, then rinsed with fresh water. You can also try Cleaning Detail on a soft towel.
    Sep 2017
    ontario
    I believe compound and a couple rags like you have been doing - in the shade . Or a buffer and save some elbow grease but it does sound like it' due. Continue with the wax cleaner minimum. Usually it' a fine compound and use an old toothbrush for rub rail seems or tape off the seems/ joints and and save that clean up . It will dry white in those seams if not and looks shoddy . Get buffing.
    Sep 2008
    Delaware River,NJ
    Try Amazing roll off. It's not an acid.
    Found this works very well. one spray, wait a few seconds, and wipe off. Also works great for seats.
  1. Rust Oleum Topside Paint
    By milkdud in forum Fiberglass and Composites Discussion
    Last Post: 04-19-2012, 05:29 PM
  2. Removing Licence #s from Hull question.
    By Adam in forum General Boating Discussion
    Last Post: 04-22-2005, 07:48 AM
  3. Removing Vinyl pinstriping from Hull?
    By mxz in forum Detailing and Care
    Last Post: 08-05-2004, 01:38 PM
