Results 1 to 5 of 5
    Jun 2019
    miami
    Donzi 22 Classic Outboard 300hp HPDI Prop?
    I have a 22' Donzi classic OUTBOARD that I'm powering with a 300 HPDI. Need to know where to start with prop?
    would like something that's works well for cruising with family with some punch. With a 300 its never going to be crazy fast but I would like to get 55mph...
    The motor is mounted onto the transom, no bracket.
    The boat weighs about 3400lbs with motor.
    Thank for the help
    Jun 2019
    miami
Name:	11111 Donzi 2.png
    Windsor, Ontario
    20" Trophy if you can find a cheap one for a baseline?
    Jul 2004
    Connecticut
    That is a round bottom 24 degree V unless someone messed with it during the conversion. You must install a manual jackplate to play around with that 25" motor and I'd start with a 19 pitch Rev 4 prop.
    Windsor, Ontario
    300 HPDI could be 25 or 30 or if its the VMAX version it's 20. Good call on shaft length. 19-20 is the right pitch range for 55.
  1. 2004 hpdi 300hp
    By 16ft superboat in forum Outboard Engines
    Last Post: 01-02-2019, 09:20 AM
  2. 22 Donzi Classic
    By Speed Jr. in forum Hulls larger than 20'
    Last Post: 07-08-2016, 05:01 PM
  3. but 1 Yamaha 300hp hpdi get one free
    By mack-the-knife in forum Outboard Engines
    Last Post: 05-08-2016, 09:46 PM
  4. Donzi classic 22
    By koukrapock in forum General Boating Discussion
    Last Post: 10-29-2012, 05:58 PM
