Results 1 to 4 of 4
    May 2016
    Texas
    Mercury Question
    98 225 promax loses power when accelerating unless I really put the petal on the floor. It also seems to be at lower rpms, when running 4k+ it seems to run fine. Any ideas/leads would be greatly appreciated.
    Injectors maybe fowled , check fuel pressure at test valve needs to be no more than 36 - 38 lbs if higher clean screen on return system under the regulator , check to see if timing linkage is sticky and not going to full advance , voltage tested at starter sylinoid and ground at starter needs to be 12.5 not running and 14 ish when running above 1500 rpms , also check voltage on TPI , with DDT attached check voltage when you raise throttle the voltage need to move upward a smooth motion . Also I have good luck with NGK BR9 HS gapped at .040” ..
    Good luck ,
    Jay
    Jay @ JSRE
  3. Likes Baker343 liked this post
    May 2016
    Texas
    Jay I have a 16 amp charging system on the motor. I'm only seeing about 13V when running. I wasn't sure if that was normal for the 16 amp charging system. Thanks
    ​Yes Sir they do t put out much voltage ...
    Jay @ JSRE
  1. Mercury Tech: Mercury 200 question
    By mt0264 in forum Technical Discussion
    Last Post: 07-15-2012, 08:46 AM
  2. Mercury 2.5 pan question
    By bigboy in forum General Boating Discussion
    Last Post: 02-27-2011, 05:44 PM
  3. Mercury 6 cyl 115 hp question
    By kevdoyle in forum Technical Discussion
    Last Post: 04-10-2007, 09:19 AM
  4. Question on a Mercury XR6 150
    By HST300GT in forum Technical Discussion
    Last Post: 04-15-2004, 03:25 PM
