Results 1 to 4 of 4
Thread: Mercury Question
06-24-2019, 12:13 PM #1Member
- May 2016
- Texas
- 34
Mercury Question
98 225 promax loses power when accelerating unless I really put the petal on the floor. It also seems to be at lower rpms, when running 4k+ it seems to run fine. Any ideas/leads would be greatly appreciated.
06-24-2019, 04:19 PM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
Injectors maybe fowled , check fuel pressure at test valve needs to be no more than 36 - 38 lbs if higher clean screen on return system under the regulator , check to see if timing linkage is sticky and not going to full advance , voltage tested at starter sylinoid and ground at starter needs to be 12.5 not running and 14 ish when running above 1500 rpms , also check voltage on TPI , with DDT attached check voltage when you raise throttle the voltage need to move upward a smooth motion . Also I have good luck with NGK BR9 HS gapped at .040” ..
Good luck ,
JayJay @ JSRE
Baker343 liked this post
06-25-2019, 02:13 PM #3Member
- May 2016
- Texas
- 34
Jay I have a 16 amp charging system on the motor. I'm only seeing about 13V when running. I wasn't sure if that was normal for the 16 amp charging system. Thanks
06-26-2019, 12:35 PM #4Supporting Vendor
- 11,838
- 163
- 11
- 795
Yes Sir they do t put out much voltage ...
Jay @ JSRE
Mercury Tech: Mercury 200 question
By mt0264 in forum Technical DiscussionReplies: 0Last Post: 07-15-2012, 08:46 AM -
Mercury 2.5 pan question
By bigboy in forum General Boating DiscussionReplies: 7Last Post: 02-27-2011, 05:44 PM -
Mercury 6 cyl 115 hp question
By kevdoyle in forum Technical DiscussionReplies: 11Last Post: 04-10-2007, 09:19 AM -
Question on a Mercury XR6 150
By HST300GT in forum Technical DiscussionReplies: 6Last Post: 04-15-2004, 03:25 PM
