Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
    Sep 2008
    Lows pressure fuel pump got them running an a heavy dose of Mercury quik clean. Starboard motor doesn’t like to idle though.
  2. #17
    Jul 2011
    Gloucester, VA
    You need to pull all the Injectors, test the and send them out to be serviced, also get the fuel rail looked at cleaned and serviced as needed.
  3. #18
    Jan 2003
    aalsmeer
    Thumbs up
    Hope this helps!
    Attached Thumbnails Attached Thumbnails MERCURY__OptiMax_Tehnicheskoe_ustroystvo_dvigateley.pdf   135-150 OPTIMAX-DIRECT FUEL INJECTION-With Serial Numbers OG590000 and Above.pdf
  4. #19
    Sep 2008
    Quote Originally Posted by PanRonnie View Post
    Hope this helps!
    Thanks!
  1. Mercury Tech: Remove and replace opti injectors
    By Cupins in forum Technical Discussion
    Last Post: 06-30-2011, 04:32 PM
  2. Sometimes Injectors won't open
    By mgraves102 in forum Technical Discussion
    Last Post: 07-01-2004, 03:39 PM
