Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 50
    Jan 2018
    Alabama
    Drilled Exhaust - Real World Results and Weigh-In On Benefits
    Guys, I want to get some real-world answers about "drilled exhaust". I've seen this done for years and while I know that noise is one downside result, is there a real benefit? I have a 20" Mercury 2.0L V6 that I'm building for myself and a later project. If I'm going to drill the exhaust, I need to do it now before I start painting.
    My gut says Yes - I say this because my 2.5L Mercury V6 ProMax SS (short shaft) is the best running/performing outboard that I've ever ran. I've owned this ProMax SS for 20 years now and it's acceleration characteristics are unlike any other outboard I've ran. The transition from idle thru hole-shot has no hesitation. There is no blubbering, no hiccups, no delay that many outboards experience when "clearing" the water from the exhaust cavity. Since the SS has a huge, open hole that vents the exhaust above the cavitation plate and does not require all of it out through the gearcase and the thru-hub system, the engine is free to spin up from idle.
    I know the openings wouldn't help WOT operation, but my thoughts are that they can't hurt idle and should aid (as do the reliefs) and they will help to build rpm quicker to clear the exhaust cavity when transitioning from deep in the water to on-plane.
    OK, if the answer is "Go", I'll place 6 1/2" holes in the outer leg (3 on each side), but where do I drill the inner exhaust liner (shown below)? Thanks, Gordon
Name:	Drilled Exhaust.JPG
    Aug 2011
    Lake Mälaren, Sweden
    Interesting question, hope to see a nice pro/con debate!
    On my looper I experience a better off-idle accel the more exh I relieve above the gearcase, despite the fact that the prop vent holes has less and less effect the more exh is relieved...
    TX......somewhere?
    Quote Originally Posted by Gordon02 View Post
    you don't..
    you throw tha liner ona shelf or in tha trash...
  4. Likes tunnelmike, sonicss33 liked this post
    Jul 2005
    AZ
    Are you doing any other work/mods to motor?
    Michael
    '84 Checkmate Convincor
    Post #3 is my suggestion , while powerhead is off you have perfect opportunity to drill 5 1/2” holes at the base of your bass midsection like Mercury sent all the 260 bass mods in the early 90’s , any gains ? It would be minimum IMO but LOTS louder that once done irreversible... Think it out ...
    Jay
    Jay @ JSRE
    May 2014
    Livingston, Louisiana
    A lot depends on motor and it’s characteristics. I had a cust call me this morning regarding a Yamaha I just built and modified mid to relieve exhaust. He wanted to know if we could relieve more, because he noticed while taking off and the exhaust reliefs cleared the water the motor would instantly spool up, so in this application it apparently is helping. I’ve also noticed on modified carb 2.5’s, the more exhaust I relieve above water line, the better they idle without loading/puddling fuel. In long idle zones you’d have to periodically bump up accelerator to keep it from loading, much better to all but gone by allowing more exhaust out above water line.
    Pekin, IL
    Remove the liner but keep it. Drill from the top down like the 260s. All you have to do to reverse it is re-install the liner.
    Rock
    Team Junk
  9. Likes Dave Strong, David - WI, mrichartz, tux974 liked this post
    Quote Originally Posted by rock View Post
    Rock
    But unless you have done major mods to the 2.0L doubt you will see any difference other than more noise.
  11. Likes tux974 liked this post
    Mar 2015
    Vancouver, Washington
    I will agree with above comments, my motor does idle much better with it all opened up. (260 with offshore mid, a drag racer cut of the end, and drilled holes every where) Real increased performance numbers will probably not be quantifiable in my opinion, unless other mods are made to take advantage of added breathing in the mid and top range. If it makes you feel better that the motor idles better, and you like the sound, then I could see how it would be fun, but that is about it. Most of my friends think I am stupid for taking the little step in performance, but I kinda like it
    Whitney Woolard
    Oregon/Washington
    '96 Allison XB2003 w/Mercury 2.5 260ss
    Jan 2018
    Alabama
    Guys, you've confirmed It's On! I'll get that 20" stock housing drilled over the weekend.
    Thanks for the inputs and advice. I'm not after the noise, but don't mind it since I've gotten used to my 15" ProMax's 4" hole under the housing (I've had that little baffle plate removed for 20 years too). I give that above-water relief the full credit for how quickly this motor spools-up on my Allison. Never a hiccup, cough, or pause - it responds instantly and always immediate. Gordon
  14. #11
    Pekin, IL
    Earlier you mentioned 3 holes each side. Like Jay said the 260s had 5 each side and Mercury felt it was a good idea.
    Rock
    Team Junk
    Pickering and Lakefield, Ontario, Canada
    Its not a Merc, but this is my solution on my 3 litre OMC's. 3" holesaw, thru the mid and liner.
  16. Likes ssv1761982, Captain75 liked this post
    Jul 2005
    AZ
    Quote Originally Posted by 58Evinrude View Post
    What year is that motor?
  18. #14
    Jul 2005
    AZ
    So are/did you do any other work/mods to motor?
  19. #15
    Drill holes in a Merc mid like that it will crack, there is a reason the Merc engineer's did the 5 half inch holes each side where they did.
  20. Likes tux974, rock liked this post
  1. Real world mpg , 300 xs vs 300 x above 4000 rpm
    By Skater 32 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 06-15-2012, 09:37 AM
  2. Merc 2.5 drilled exhaust
    By Liberator225 in forum Technical Discussion
    Last Post: 05-20-2012, 04:47 PM
  3. Drilled exhaust
    By ridinsuicide in forum Technical Discussion
    Last Post: 07-03-2005, 02:18 PM
  4. The REAL World........
    By Mike Watts in forum General Boating Discussion
    Last Post: 11-11-2003, 05:07 PM
