Results 16 to 18 of 18
Thread: Fuel line
06-25-2019, 03:40 PM #16Member
- Feb 2019
- Grand Haven Michigan
- 40
Ok, yup, I see 1094 on it. Assuming 10/94. This is going to suck.
06-25-2019, 04:40 PM #17
10' of it for $38.00 at Wallyworld https://www.walmart.com/ip/Shields-M...?selected=true
rochelle howell thanked for this post
06-25-2019, 04:53 PM #18Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10931
My local hyd. supply place has it for even less than 3.80/ft. Might check around locally. Also measure to see exactly how much you need.
Mercury Tech: 3 problems: Fuel mist from oil line, overheating, and fuel leak re: 1989 v6 150 2.0L
By pjbrownva in forum Technical DiscussionReplies: 42Last Post: 06-04-2019, 11:14 AM -
Mercury Tech: Fuel line, vacuum hose, and water line replacement
By RHafley in forum Technical DiscussionReplies: 1Last Post: 12-23-2017, 08:43 PM -
Fuel Line/Bleed Line Routing for '96 2.5 200EFI
By Hydrasports205 in forum Technical DiscussionReplies: 2Last Post: 09-11-2017, 11:08 PM -
Clogged Fuel Line??? Difficult to pull fuel through fuel line.
By supervetteracer in forum Technical DiscussionReplies: 13Last Post: 04-30-2016, 09:08 AM
