Results 1 to 12 of 12
Thread: Video clip: Is this too low?
06-20-2019, 12:58 AM #1Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
Recreational bowlder, video to follow. I just threw in the pic to show what kind of boat it is:
2.0L V150 Merc. Can do over 50mph if not overloaded. Anyway, I shot this clip yesterday cruising about 35mph. Does it look like the anti-cat plate is too low? I fee like it's skimming and not submerged. BUT, should it be clearly higher. As the video title says, it's only got one more hole to go before it's all the way down. Non adjustable jack plate.
Would you raise it a hole, or is it good?
Sorry for the vertical camera. It was safer to hold the phone that way.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
06-20-2019, 07:59 AM #2Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
I would raise 1 hole. You want to see the cav plate at the surface. The way it is, is great for pulling skiers and such with no cavitation. I think you will still be good going up one hole.
06-20-2019, 08:00 AM #3
Too low cav plate should be above water
06-20-2019, 12:14 PM #4Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
06-22-2019, 03:42 PM #56000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
You could probably go up two if you wanted. Your good with all three. 4 up I would check water pressure before trying all the way up.
1 up will give you a lot though.'06 Tracker All-Fish/Tournament V-18 90 Optimax, 46.8 gps Goal one complete reach 45 mph.
06-23-2019, 06:29 AM #67000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
I run my motor all the way up on the jack plate. Plenty of water over the bullet. It's on a 19 cuddy cabin. The cav plate is just above the water when trimmed right. No lwp, lightning gear case. But I think a standard case would still get water.
07-21-2019, 08:31 PM #7Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
I raised it one hole. Running a straight edge from the pad to the foot I get this: (no idea why it’s upside down. I’ll try to fix it when I can ditch this iphone and get a real computer The original is not upside down )
[IMG]AMatI6fFvA25SmqQ-GTwJ9jTUS1fyvX9UdYFtVbtwfEmZDekjokHOf1YT0u6_hmKbW13irkwRn0jE61h-533taIkqFLLgy8axm1TQDAKR9AgyTYGKBbZKTA7UgWwE_Hu1o-sK-6OayZwPc1CD-sD8JrBOq2umcG99-J5nSGsQHX40HoBd0WWSAWR7Y0iQui8EPDOTERG8UeupGi6GdIhrY4a1olHm1Tz3XR0mxe_OWi6eqHrQUKrlPHhDo1t-J4fEjubuAWMv6o_tfyNPzjDXyRUIioBNMWgaXlukqDZ_X0971tgF7V17uC5di4CuWKVdnlcTooW7odVJu2pVgHIVfueUKHMvJALr Ps_3oqd381J1bWj-iQuIccmX6hn4nTfdayoytTSMuUiNawptDsk6SryITP2FDgnT8MvJhuXtfuE-VsQx85TD_mo-LnVU5KX2cZuy2xMuCAqTgu5Y7L5k7qembZCZ_JMnDq0AzGApaf4WQT_5EecGxJUOHZimhoBfnpAXbA4IFULg0fgEbbuv6nC8HcRn gg3gYq20NEHEyFAqpjoVK5FiHeUzn7LEH4e2Fa04mnc--gQh9TvzNb-zo1Klz7ilbpXUQHBu1A73R39AzAdyH297q0mIUS0DM2dQrAlRwzK-KHf6jYR02zN3xu6_jhfTtCX=w978-h733-no[/IMG]Last edited by pcrussell50; 07-22-2019 at 11:17 AM.
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
07-21-2019, 09:49 PM #8
Was that at or close to WOT trimmed out correctly? If it isn’t then you really don’t know where it’s running and could starve the motor of water or blow out the prop at WOT.
Mark
07-22-2019, 11:21 AM #9Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
07-25-2019, 09:05 PM #106000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Should be fine, most beep if pressure is low. Don’t rely on that though.
That should only only make the a/v plate visible.
Whats not discussed is you probably wont gain much or you could gain 10mph y being able to pitch up never know.
07-27-2019, 04:14 PM #11Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
I dropped it back down a hole, to the original position. No more prop blowing out, either. You can still see the AV plate, but it’s obscured by spray (possible because the bottom edge of the transom has a little lip that dirties the water as it leaves the hull. Gonna have to fix that next.
__________
the wet:
the dry:
2003 bmw ///M5
07-28-2019, 10:37 AM #126000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
That might be the anti chine walk lip, only mess with it with care.
Spy video clip lcb td/se catt
By scawd the dog in forum General Boating DiscussionReplies: 7Last Post: 08-17-2011, 07:54 AM -
Getting Air in Key West Video Clip
By Sharkey-Images in forum General Boating DiscussionReplies: 23Last Post: 05-19-2006, 12:04 AM -
How can I post video clip
By Donat in forum Computer and Forum SupportReplies: 13Last Post: 11-10-2004, 06:15 PM -
Looking for Blow-over video clip
By pyro in forum General Boating DiscussionReplies: 19Last Post: 07-09-2004, 06:15 PM -
Video clip
By pyro in forum General Boating DiscussionReplies: 9Last Post: 07-10-2002, 09:28 AM
