Results 1 to 15 of 17
    Jun 2017
    Georgian Bay ON Canada
    Mercury xri ECU fuel pump bypass
    I have a 1995 XRI 150 that is not sending a signal to the fuel pump when ignition is on. I had a negative lead come lose from my battery causing this issue to start, it also fried my tach. I have read there is a way to bypass the ECU, I have read a couple different ways that people have done it, I would like some opinion on the "correct" way to go about this.
    Thanks!
    Buy a 30 amp relay , connect positive of fuel pump to relay and continue from relay to positive of battery Next connect negative on pump to negative on battery , find keyed switched hot PURPLE wire from key switch harness to relay using it as your exciter wire . When key is off relay opens killed power when key is on relay is excited and closed starting pump I’ve hooked lots of them that way when fuel pump circuit is not working on ECU .
    Jay
    Jay @ JSRE
  3. Thanks coffeeguy thanked for this post
    Likes W2F a V-King, Aa Hayes, Capt.Insane-o liked this post
    Jun 2017
ID:	442454Sorry for my lack of knowledge. How do I wire this in?
    thanks for the help guys, much appreciated!
    Feb 2013
    Northern Cal
    YouTube videos on connecting these type relays check em out
    Jul 2011
    Peterborough, On
    The wiring diagram is right there on the relay! Not to be an a$$, but if you can't work with that, you should really take it to someone who can. Some things shouldn't be left to YouTube, an electrical fire in a fiberglass boat is no bueno.
  7. Likes Euroski liked this post
    Jun 2017
    Quote Originally Posted by idvette View Post
    I have done plenty of electrical, I have simply not wired in a relay before. With some simple guidance it would be an easy install, I am looking for someone to say this goes there this goes there and bingo, "so I get it right." Maybe with all your wisdom you could do this rather than being judgemental towards someone and their situation you know very little about...
    Give me a call I do my best to walk ya through the wiring , Ive done plent of them your ECU wiring to the pump isn’t uncommon ...
    Jay @ JSRE 832 597 2603 most anytime !!!
    Jay @ JSRE
    Jun 2017
    Quote Originally Posted by Jay Smith View Post
    thanks Jay.
    does later afternoon work for you? I can be to the boat around than, if not I can call through the day and take notes.
    Jul 2011
    Peterborough, On
    Quote Originally Posted by Aa Hayes View Post
    Like I said, not looking to be an a$$, sorry you took it that way, just looking out for your safety and that of people you have on board with you. The relay you are working with isn't even a marine relay, so things like water and gasoline fumes can easily get inside the casing and cause major concerns. (Read: unwanted thermal event)
    A relay is simply a low amperage circuit controlling a high amperage circuit. Pins 86 and 85 are the low amperage "control" side. Switched power in on pin 86, ground pin 85. Pin 30 is your high amp fused input to the relay, pin 87 will be your load. 87a is where the high amperage side of the relay rests, you won't be using it so best to terminate that wire so it doesn't short anywhere.
    Jun 2017
    Thank you for that, I appreciate the input and concern of none marine relay. I will exchange for marine relay.
    I come here for good advice for things I have the confindence to do on my own but lack the knowledge. I build houses for a living, not boats, but I am knowledgeable and love to learn. If I was not comfortable and thought it was unsafe I would not perform the job myself, I would never put my family or friends at risk.
    Anytime is good for me , call at your leisure Im off today YEA !!!!
    Jay 832 597 2603 CST
    Jay @ JSRE
  14. #12
    Jun 2017
    I just wanted to say thanks Jay, with a little explanation of how the relay works I was able to easily install and get the fuel pump running. Also Idvette suggested a sealed relay unit which I used.
    The motor dis not want to fire which is unusual for this 2.5 it has always fired up for me. I am hoping that I did not burn up my Ecu when the ground on my battery came loose last fall. I was unable to check for spark as I was at the boat with no spark tester and no one to check spark. What is the method to test Ecu and also stator?
    thanks
  15. #13
    Jun 2017
    So, I went out to the boat today, lots of healthy spark. So I pulled the plugs and found all 6 to be bone dry. Put a little fuel in each cylinder and she fired right up until the fuel burnt off. I checked fuel pressure, it was good. My guess is the ECU is not send an injector pulse signal. Thoughts?
  16. #14
    Sounds like good troubleshooting , just make sure availibility of fuel is there for the pump to pick up and pump when you turn on key listen and feel if pump is running . If it is remove brass plug under VST tank and check for fuel inventory there if not may be a bulb fuel lines or vaccume pump issue ...
    Good luck ,
    Jay
    Jay @ JSRE
  17. Likes Aa Hayes liked this post
  18. #15
    Jun 2017
    I cracked the fuel line in and out on vst, fuel both sides. Good pressure at the test valve. I am leaning towards in being no pulse signal from ecu to injectors? Can an air lock occur there, I am assuming not. Is there a way to test pulse signal to injectors?
  1. Lazer fuel pump circuit bypass
    By warhawk 300 in forum Technical Discussion
    Last Post: 12-20-2018, 10:04 AM
  2. 99 OPTIMAX FUEL COOLER BYPASS? vst pump wrong?
    By ljay in forum Technical Discussion
    Last Post: 01-11-2017, 06:58 PM
  3. ? bypass oil pump
    By mofo in forum Technical Discussion
    Last Post: 01-24-2009, 06:26 PM
