Results 1 to 8 of 8
06-19-2019, 08:15 PM #15000 RPM
- Aug 2008
- ILLINOIS
- 183
- 13
1991 2.5 245 HP cutting out at high speed.
Open to anyone that might know whats wrong with my motor . Was rebuilt late last year with Wizard pistons and CCM reeds. Barely put anytime maybe 2 hours before going into storage last season. First time out after about 30 mins of run time it cut out as if it had a rev limiter on it. It stalled started up but could not go over 2000 rpm, would want to shake and stall so ran at about 1200 rpms to get it home. Tonight ran compression test all at 130psi. Also ran spark test all plugs have spark. at 1000 rpms ran fine. So i will start process of checking electrical with ohms meter tomorrow.
Motor is 100% original on all electrical except starter rebuilt and new plugs. So my guess after 28 years something failed.
My first thought trigger of stator ... has anyone else have this happen to them?
Thank you
06-20-2019, 03:57 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The lovely MERC stator..... Just ge a 5454......a7......and a red flywh.....
mercrazy liked this post
06-21-2019, 05:27 AM #3
tux974 liked this post
06-21-2019, 07:29 AM #45000 RPM
- Aug 2008
- ILLINOIS
- 183
- 13
Was on line last night tracking down all Merc parts as I am not a fan of the after market unless OEM is no longer made.
Thank you
06-22-2019, 04:32 AM #5
good ta ya!.. some have luck with after market ****.. I jus wasn't one of 'em..
06-23-2019, 10:23 AM #6
I had the same problem years back on my Bridgeport after hitting a submerged log at low speed. Turned oun to be the trigger.
07-01-2019, 02:34 PM #75000 RPM
- Aug 2008
- ILLINOIS
- 183
- 13
07-01-2019, 08:37 PM #8Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
happy is good......eating all the dino piss.......heehee........
remooving low speed/high speed spark advence module
By jmr112 in forum Technical DiscussionReplies: 15Last Post: 12-14-2016, 10:46 PM -
1985 merc 150 cutting out at high rpm
By Keaten in forum Technical DiscussionReplies: 12Last Post: 10-15-2015, 04:41 PM -
Makita high speed buffer, variable speed
By BUD in forum Non-Marine ItemsReplies: 0Last Post: 10-10-2015, 01:22 PM -
1991 2.4 Fatblock Cutting Heads and other cheap hp gains
By coffeeguy in forum Technical DiscussionReplies: 0Last Post: 12-27-2014, 01:54 PM -
300 ProMax Cutting Out at High RPM!!!
By BM in forum Technical DiscussionReplies: 10Last Post: 06-13-2005, 02:07 PM
