Results 1 to 2 of 2
    May 2019
    Anderson sc
    99 yamaha S200 TXRX
    I have a 99 Yamaha S200 TXRX carbureted injected outboard. The issue I am having is looses rpm's randomly. turns 5200 for several miles then starts losing rpms down to 3200-4000 rpm. I have had a timing light on the motor when it does that and its all over the place. I can stop shut down and start back up and sometimes it runs fine. things I have done complete fuel system from tank to fuel pumps and carbs. Stator checks good, pulsar coils good, crank sensor good and voltage regulator good. cdi output is good when motor goes into mode. All coolant sensor and temp senders good motor runs around 130-135 degrees. Can this still be the cdi since it controls the timing? Any Yamaha guys that can lend a hand I would appreciate it...thanks
    May 2019
    Anderson sc
    all checks have been done per manual with dva meter running cold and hot. it has also done this cold right when I put it in the water.
  1. 1996 Yamaha 200 Mids Interchangable with Older Yamaha Powerheads
    By bigshrimpin in forum Technical Discussion
    Last Post: 05-21-2020, 04:03 PM
  2. Replies: 0
    Last Post: 05-02-2011, 09:06 AM
  3. Yamaha Tech: 1998 s200 carb saltwater series II
    By Six Four in forum Technical Discussion
    Last Post: 09-24-2009, 10:37 AM
  4. Yamaha Tech: Yamaha O2R96V2 Digital Mixer, Yamaha YBS-52 Intermediate Bari Sax
    By pioneer01 in forum Technical Discussion
    Last Post: 07-03-2009, 09:13 AM
