Results 1 to 2 of 2
Thread: 1995 xri 150 fuel pump no pulse
06-18-2019, 07:33 PM #1
So, I had a neutral wire come loose on a battery... motor lost power,
fuel pump has no pulse, power to pump,
installed a new pump, still nothing, power to positive and negative side on pump. Did I cook my ecu?
also burnt out tach..
thanks!
06-18-2019, 09:52 PM #2
I'm no efi mechanic by far ,but I hear of the fuel pump driver goin bad in ecu all time. Lots of guys here know how to run that separate wire of that's what it is
Mercury Tech: mercury 200 hp fuel pump pulse chamber differences between #79826 & 86449
By buzmacdowell in forum Technical DiscussionReplies: 0Last Post: 08-12-2017, 08:53 AM -
Mercury Tech: 2.4 225 Pulse pump setup
By 1BadAction in forum Technical DiscussionReplies: 19Last Post: 05-11-2016, 08:57 PM -
Mercury Tech: 1995 Mercury EFI Fuel Pump Issue - Power, won't work
By mram10us in forum Technical DiscussionReplies: 15Last Post: 05-06-2015, 11:10 PM -
pulse pump or electric
By dangerousd in forum Technical DiscussionReplies: 7Last Post: 09-08-2010, 10:34 PM -
Recommendations on a fuel pump and regulator for an 1995 EFI Mercury 2.5 260 HP
By trabah01 in forum Technical DiscussionReplies: 2Last Post: 05-26-2010, 06:09 AM
