Results 1 to 7 of 7
    Jul 2007
    Left coast Ca./Willow Valley AZ.AKA Lenny
    Mirage prop question
    Running a 28 mazco3 blade and boat pulls it want to try a 30, any suggestion and also 3 or 4 blade
    Willow Valley AZ.
    Mar 2002
    Lake Havasu
    Lenny, I have a 30 Mazco that you can try if you'd like. Be great to see you again!
    Baton Rouge, La
    I liked a 30et on my ski racers. Carried weight well also. What motor and what are you trying to accomplish ? Mike
    Cheaters never Win !!!
    Jul 2007
    Quote Originally Posted by outboardrick View Post
    Thanks Rick need to do a little work to the old girl, I will call you soon.
    Willow Valley AZ.
    Jul 2007
    Quote Originally Posted by tunnelmike View Post
    200 efi with ECU upgrade , has a 28 and runs 89 mph all day, just want to try a 30 but should I run a 3 blade or 4 blade ?
    Willow Valley AZ.
    Baton Rouge, La
    Ive never had a chance to run a 4 blade. I tried any prop I could get my hands on and bought the ones that ran good or one like it. My 96 ski racer with a 95 xri with minor exhaust chest work and 145lbs compression would run 103 with a 32 mach with the stock ecu.
    Try as many as you can to see what works best for you. It can get expensive buying a bunch of wheels that don't work for your application. Good luck. Mike
    Mar 2002
    Lake Havasu
    Quote Originally Posted by baja1000 View Post
    I also have a Mazco 28 4 blade that has been cut to an ET type blade by Ron Hill.
  1. prop question on my mirage
    By banchee6 in forum Props, Setup, and Rigging
    Last Post: 05-13-2009, 08:58 AM
  2. help on prop set up on a mirage
    By rudejunkie in forum Technical Discussion
    Last Post: 07-11-2008, 09:39 AM
  3. Mirage Plus prop
    By cocacola in forum Props, Setup, and Rigging
    Last Post: 05-20-2008, 01:45 PM
  4. Mirage Prop Question
    By sshatswell in forum Technical Discussion
    Last Post: 01-31-2007, 07:21 PM
Diamond Marine
