Results 1 to 6 of 6
    Jul 2007
    Negaunee, Michigan
    Question Evinrude Gearcase Question?!?
    2004 Evinrude DI 225HO MDL# E225FHLSRM SER# 05070007
    I tore up the gearcase that’s original to the engine. Based on the model number the gearcase is supposedly a “lightning” gearcase.
    My question is, will a magnum gear case work on my engine? I know it bolts up and the drive and shift shafts all align properly, but will I experience any operational problems down the road by using the magnum lower unit?
    1992 S.T.V. ProComp - Merc. 2.4 BP EFI Sold!!!
    ft pierce fl
    I am not sure but i think Lightning gear case were all 1.87 ratio. The L1 had round holes for water intake. The L2 also 1.87 but has plastic grates for water intake. The Magnum had 1.71 ratio for a few years. I have never heard of anyone happy with performance with a 1.71 case. I think newer Magnum cases went back to the 1.87 ratio. The 1.87 Magnum is a stronger lower then a Lightning L1 or L2. The bigger diameter case the Magnum has will not run as fast on a 70 mph+ boat. I think if boat is a heavy 65 mph bass boat the Magnum probably is the best choice. Disclaimer. I am Asst Manager at Burger King. I get my info from random post that may or may not be accurate info.
    May 2001
    Hickory NC
    Dave is correct except the Magnum is 1.85 ratio. The L2 had the 1.71 gears when delivered on a 250HO
  4. Likes davemvegas liked this post
    Jul 2007
    Negaunee, Michigan
    So, it’s your opinion that the magnum case will work on my 225. The engine is on a 22’ Tri-Toon so if the magnum is a stronger setup, I may actually benefit from it?
    What do you think?
    Dec 2001
    Davemvegas Is that girl in the photo one of your girls behind the counter......no wait it was the guy with the gearcase ???? what was I looking at.........twin pinion gearcases all ways get me......
    Jan 2008
    SUMMERVILLE S.C.
    ya.. the magnum would be a better gearcase on a pontoon than a lightning...better ratiofor that.... and heavier gearset
  8. Likes racer liked this post
  1. Evinrude 250ho G2 SLX gearcase
    By chad.r in forum Technical Discussion
    Last Post: 01-01-2017, 06:03 PM
  2. 235 HP Evinrude Crossflow Gearcase
    By 97mirage in forum Parts Wanted
    Last Post: 09-06-2013, 08:55 AM
