Results 1 to 13 of 13
    Sep 2018
    Cape Girardeau Missouri
    Where to find 260/280 new Bosch pump and Black 56psi reg.
    Have made lots of calls and getting different info from every place. Bosch says the 0-580-254-950 pump is still available under that # and also # 69608, but when calling Summit racing they cant cross or pull up the 10 digit # and the 69608 # they no longer sale. When talking to NAPA, they can pull up both #s but the 0-580-254-950 pump is 360.00 and the 69608 # cost 160.00 and pics are different. Also read in a blog that the Summit racing pump # 69513 was the correct pump for 147.99. Brucato stopped selling the pump and could not tell me the pump that they used to sale. And for the regulator, Bosch says they discontinued it 8 years ago and that I would have to email their motorsports division to get advice on a replacement for it. Any one have confirmed info that is confirmable or proven?
    Aug 2015
    Southeast
    Just went through this myself for a 280. I didn't need a regulator though. The part number for the pump I bought at Oreilly's is listed further down in the post. It's confusing as the Bosch boxes have 3 or more different sets of numbers on them.
    https://www.screamandfly.com/showthr...=280+fuel+pump
    My drag motor Bosch fuel pump I use on my run stand said good bye a while back had issues finding replacement , called Pro Marine no luck with Bosch , BUT they did nave an electric pump looked like a clone but skinnyer than the Bosch , I’ve been running my builds using it for several months with no issues , I called the other day ordering parts and was gonna order a spare and it was sold out , I got on the waiting list , if memory serves me it was less than $100 and it is pressuring up the black as well as the gold regulator motors with no problems ....I do have a black regulator I’ll sell if your interested ...
    Jay
    Jay @ JSRE
    Sep 2006
    Key Largo, Fl
    The pump has to have not only the necessary pressure,but be able to maintain that pressure at WOT,20-30 gallons per hour,or more...test running a powerhead under a no or minimal load condition will never approach the volume use necessary for loaded full throttle.If Pro sells the pump for the application I would assume it's adequate,but I would still make sure the system,not only the pump,can maintain pressure at all times,Chris
  5. Likes Michael J Giesler liked this post
    Sep 2018
    I have emailed Bosch motorsports and gave them the run down. Waiting on info from them. Will relay info to this post when I get an answer.
    That was - is the pump Pro Marine was selling to replace the Bosch (56 and 39 regulator motors I was told ) that seems to be a bear for folks to find ...
    Also the size of the physical pump means nothing in regards to the pumps performance curve and gallons per minute it can and will pump !
    Jay
    Jay @ JSRE
    Moline,Ill
    It's been forever since I bought new pumps, but if I remember they were for a Mercedes SL500
    https://www.ebay.com/itm/Mercedes-Be...5.c10#viTabs_0
    is gone
  9. Likes Michael J Giesler liked this post
    Moline,Ill
  11. Likes Michael J Giesler liked this post
    Thebes, Il.
    Cary, I can't help you out till next week but I may have 2 different options here in Thebes for you to look at. Might consider a Aeromotive regulator or similar from Summit. I will get with you 1st of next week. Roy.
    Current-
    '89 Allison XB2002 Comp/Pro Center Steer Maroon on Sandstone
    '98 ProMax 225 JSRE
    20" Mid- Jaco's Ally worked SportMaster 1.87 gears
    Past-
    '96 Allison XB2003 PST White w/ Red Tips accent Stripe
    '89 GT175 w/Bob's Bigfoot LWP
    '97 Cobia 22BR 5.7 MercCrusier/ Bravo
    '85 STV Sprint --2.5 Ported Smiling Jacks Horn EFI system 10k+RPM
    '87 HydroStream V-King YT OMC 235 V6
    '77 Glastron CVX16-- Beaver Tyler built V4 Johnson
    Kona DayCrusier
    17' Contender
    XB03AllyProud on other sites
    Aug 2015
    Southeast
    I have an 11 page pdf Bosch sent to me. Lists tons of their fuel pumps and stats. I can email if anyone wants it, PM me. The one I bought is 0580464126. Jay texted me a number for a pump from Promarine but I already had the Bosch pump so I kept it. The original pump I had was from a Merc Drag motor and this is the part number I was told superseded it. It's working well. Best I can tell from the metric chart in the PDF, the 0580464126 will pump 175 liters per hour at 325 kpa or about 47 psi.
  14. #11
    Sep 2006
    Key Largo, Fl
    So...thats an unfiltered (unrestricted) 46 gallons per hour at 47 psi...add filters,90 degree turns,fuel lines etc...to me sounds like it could become marginal,especially with a little contaminate in the filter...,depends on the motor,I run a pressure gauge on the dash,Chris
    Mar 2012
    Lake Hopatcong, NJ
    I also run the 126 and I’ve flow tested it in my race boat. In my configuration with 1/2” suction side, water separator, then 3/8” feed with inline filter, and 3/8” return, it delivered 163LPH, 43 GPH, while consuming 5.7 amps at 39 psi flowing through the fuel rail and back to the boat. For those that care about such things…
  16. Thanks DangerNewb thanked for this post
    Feb 2007
    lily lake WI
    The Bosch 044 pump also works for 39an56 lbs motors also
  1. Need a Bosch black 56 lb fuel pressure regulator .
    By Tom Foley in forum Parts Wanted
    Last Post: 04-07-2018, 09:39 AM
  2. HELP! new 280 and Bosch fuel pump, pump dosen't want to go????
    By blkmtrfan in forum Technical Discussion
    Last Post: 05-20-2003, 07:26 PM
  3. BOSCH INJECTOR FLOW @ 56psi?
    By Graham in forum Technical Discussion
    Last Post: 02-24-2003, 09:56 PM
