Results 1 to 5 of 5
    Calgary, Alberta
    Easily Sprayable Urethane Bedliner ?
    The original 1986 Imron paint on my Scarab’s trailer is finally failing in several areas (not bad for that old !). I’d like to re-spray once and be done with it, with something more resistant to rock chips. I know guys have done this with truck bedliner before, but I want it to look decent, without super heavy texture. Any suggestions ? I was planning to use my 3M Accuspray gun with the huge tip. I’m aware of the isocyanate risks with spraying urethanes and I’ve got that under control.
    thanks,
    Matt
    Have to ask , are the rails solid inside to outside in those areas? Two part epoxy paint if you can still get it , tough stuff.
    4508-9990:4508-9999 at 1:1
    Blasted the rails to bare metal and didn't use primer, 12 years later still hard as rock , two - three light coats. Never been inside , used through the salty Ontario winters
    http://www.reconcoatings.com/paintda...EVOE/4508H.pdf
    Was recommended by a heavy trailer guy.
    You can ad pumice stone to give texture grip.
    Calgary, Alberta
    Thanks for your advice FMP, I have used Devoe products before for some architectural applications, they do make some good stuff. Did this one go flat and chalky over time ? That’s my limited experience with epoxies as topcoats.
    Its a C-channel trailer.
    Matt
    NE Louisiana
    How long is it? Find a powder coat shop with a large oven. Just another option.
    Hard to beat Imron though. I think I would paint it, and I HATE painting trailers.
    Galveston County,TEXAS
    i used Raptor liner 2 part urethane off Amazon. Used the black and the tintable both with great results. the kit comes with a gun and its not hard to vary the texture to your liking. Proper prep is the worst part but its very easy and very forgiving
    limited skills
  1. Mercury Tech: 94 Mercury 200 XRI EFI won't go in reverse easily
    By Rgpracer in forum Technical Discussion
    Last Post: 11-14-2014, 08:13 PM
  2. Spray on Bedliner on the floor?????
    By jeffbare in forum General Boating Discussion
    Last Post: 11-25-2005, 09:52 AM
  3. Bedliner on the floor?????
    By jeffbare in forum Appearance Mods
    Last Post: 11-22-2005, 07:18 AM
  4. spray on bedliner
    By Steven in forum General Boating Discussion
    Last Post: 04-05-2004, 05:36 PM
  5. Since most have trucks, bedliner question
    By Jeff_G in forum General Boating Discussion
    Last Post: 03-11-2003, 07:39 PM
